    Quad chamfer corner question
    10 Posts 4 Posters 2.7k Views 4 Watching
    • PixeroP
      Pixero
      I'm trying to understand how to calculate the position of the middle vertex in a quad chamfer where all faces are planar quads.
      How is the lenght of the blue line calculated?
      I've made the simplest possible example scene to try and understand how it works.
      Quadcorner test.skp
      • C
        CAUL
        If I understand you correctly, this is how I would solve it
        The corner "hole" consists of 6 edges (see image). Two edges defines a plane represented by an array of the form [point, normal]. If you have two edges with a common vertex the normal is the cross product of the edges:
        normal = e0.line[1].cross(e1.line[1]) plane = [e0.start.position, normal]
        Given planes pl0, pl1, pl2 for the edge sets (red, green and blue in the image), you can now calculate the point:
        line = Geom::intersect_plane_plane(pl0, pl1) point = Geom::intersect_line_plane(line, pl2)
        The point represents the position of your vertex in the corner.
        • PixeroP
          Pixero
          Thanks, I'll try that.
          • thomthomT
            Did you find a solution?
            Did you create a quad-chamfer extension? o_O
            • PixeroP
              Pixero
              I looked into it but hadn't the time needed to solve it so hoping someone picks up on this and creates a quad chamfer plugin.
              • sdmitchS
                sdmitch
                I did this six weeks ago. Sorry for not posting it sooner.
                Quad Chamfer.rb
                http://sdmitch.blogspot.com/
                • PixeroP
                  Pixero
                  Wow! Would it be possible to have the script do the chamfering/fillet of edges with a radius/offset setting and a segment setting and not just the corner?
                  Like Image 1 and 3 in this example.
                  http://help.autodesk.com/cloudhelp/2016/ENU/3DSMax/images/GUID-E1FC8441-C6EA-4500-A9DD-78207AC06396.png
                  • sdmitchS
                    sdmitch
                    Isn't that what the Round Corners plugin does?
                    ps. The Quad Chamfer plugin executes with a left click when the Yellow edges appear instead of the Messagebox.
                    • PixeroP
                      Pixero
                      Round corner plugin is great but creates a triangel at the corner, so an all quads chamfer/fillet plugin is still needed.
                      I've asked for him to fix it but nothing has happened so go for it! πŸ‘
                      • thomthomT
                        I guess Fredo is occupied with Animator these days.
                        It would be great if more extensions could be made available on GitHub, BitBucket with open source licenses - allowing people to add to existing extensions instead of re-implementing similar functions.
