Nested dynamic components
Yes for doors, I'm working on windows and on a wall maker.
As you probably guessed - that bifold came out of my door maker.
That sort of thing interests me a lot more than cabinets.
You're talking about walls doors and windows all in the same plugin?
Garry and JQL thank you for your extensive answers. I'll process them tomorrow.
Thanks to the explanation:
@garry k said:
Think of it this way
The top most component (Mother) gets rotated 90 which rotates both the grey and the white panels.
Then rotate the gray one -180it makes now perfectly sense to me.
JQL
3 separate plugins.
@ JQL
I've just checked out your fb-gallery and I like your attic renewal, the material choice and integration of old stuff which was already at the attic before the renewal gives it a warm and cosy feeling. I also like pure minimalistic designs where warm wood tones are mixed with grey concrete tones, like your office, this is like wood and stone. This in combination with some plant green always works for me. Furthermore I like the tiny garden. I am interested in the utilisation of small spaces, like micro houses, micro homes, capsule hotels.
juju
I haven't got very far with the window plugin. I have been concentrating on a wall plugin - then I'll go back to the window plugin.
Ok, I think I got it. I had a problem to understand what relates to what.
Which purpose has:
Custom
Rotation 0?
The sole purpose of it is to display if the the state of onclick is set to 0 or 1 - is it?
@newnoob said:
@ JQL
Thanks newnoob...
We are working on a new site and we have some new projects on that line, so keep in touch!
Yes
The Mother component has an new variable that you add called Rotation.
Rotation starts out = 0
Click once and Rotation goes to 1
Click again and Rotation goes to 0In a situation where you want more than 2 states - separate them by commas.
So for a 4 state variable where you might open and close the door in increments.
ANIMATESLOW("some variable", 0, 1, 2, 3) -
@garry k said:
Yes
ANIMATESLOW("some variable", 0, 1, 2, 3)Yea I get it now. It's basically math with functions and variables, variables which can be defined at one place to use it at another, not so complicated actually.
Thank you for your time Garry.
Especially -
The top most component (Mother) gets rotated 90 which rotates both the grey and the white panels.Then rotate the gray one -180
- was an eye-opener.
Register LoginAdvertisement
