    HELP error message
    3 Posts 2 Posters 539 Views 2 Watching
    • holmes1977H Offline
      holmes1977
      Havent had this problem before. Every time I open this job and all the previous saves in this job I get this message:
      The object area "Foundation" has been deleted or removed in the models hierarchy, please select it again.
      When I press OK, sketchup freezes for a while. Then the message pops up again. I cant even close sketchup, without opening Task manager and forcing a shut down. I have been using Skatter and think I may have named a group "foundation"
      http://i607.photobucket.com/albums/tt154/holmes1977_album/Problem.jpg
      Exaggeration makes a dull story better.
        holmes1977
        Surprised no one else has had this problem. Thanks for those that read and tried Im sure.
        Cheers
        Jonathan
        • andybotA Offline
          andybot
          does the popup go away if you disable skatter from loading at startup?
