    Component attributes update problem
    6 Posts 2 Posters 1.0k Views 2 Watching
    • JujuSKPJ
      JujuSKP Extension Creator
      Hello,
      I try to find a solution to automatically update all the attributes ( like name, summary, itemcode … ) for the same duplicate component.
      An exemple to be clear,
      I draw a « pencil » and create a component.
      on the attributes I write « pencil » for component attribute « name » and « blue » on « summary »
      I duplicate this component 10 times.
      After, I select one and I change « summary » writing « black » instead of « blue » because I decide to change the pencil color.
      If I select an other component, the « summary » case still show « blue » instead of « black » …
      I try to save my good component ( the « black » one ) and I reload it … my attributes are not changing …
      I made a lot of research on the net and test some plugins … but impossible to find a solution …
      I hope I am enough clear ( i’m french 😄 )
      Thank you for your help
      • sdmitchS
        sdmitch
        Hello,
        You need to associate the attribute dictionary with the components definition not the instance.
        http://sdmitch.blogspot.com/
        • JujuSKPJ
          sorry I am not understanding how to associate the attribute with the component definition not the instance, can you explain please
          thanks
          • JujuSKPJ
            is there a function I can use to always refer attributes to definitions of the component and not individual instance ?
            • sdmitchS
              sdmitch
              thanks
              If ci = a component instance then ci.definition would refer to the component definition of that instance.
              So ci.definition.set_attribute("Dictionary","Key","Value") would be needed to create the attribute and ci.definition.get_attribute("Dictionary","Key") would retrieve it.
              • JujuSKPJ
                Thanks for your reply.
                I finally use classification ( an ifc one ) for components and put all my parameters on it ( ref, name, details ... ). That allow me to avoid the "instance" use and exploit my component definition on layout drawings notes ( on that case it is for electrical draw with a lot of repeated references/details ).
                regards
