    Using Shadows
    3 Posts 3 Posters 704 Views 3 Watching
    • G Offline
      garystan
      Hi everybody :
                 Is there a way to use SHADOWS to make "longer" trails of sunlight across the floor.   For example :  Setting the angle of the SHADOWS so that it would depict the sun at a lower angle for sunsets /sunrises. So that the sun would stream across the floor. I notice that SHADOWS is limited.
                                                       Thanks,
                                                        garystan
      • pbacotP Offline
        I guess because of "shading" of surfaces, the shading becomes darker and the shadow becomes fainter. Adjust light and dark (helps a little) in the shadow windows. Or use the ground plane as your floor. Or use a renderer.
        • BoxB Offline
          Lengthen the shadows by adjusting the time of day and time of year.
