Overlaping meshes on Z axis
no mater what i do i SKP..
tryed it all(i think)....groping componenting exploding ...
meshes that "overlap" on the Z exis disappear..
insted ..it makes a "hole" and then star building on the hole (Z axis)..
making the concting very brittle,,how can i make that it will print a "top layer"...and then start the next part on top ?
what im missing over here?using:
FFCP
S3Dcheers.!
Hi, the easiest way is to make the contact area larger if possible. You may also use a higher percentage of infill - up to 90%.
