    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Knowing that a face contains another face using Ruby API ?
    10 Posts 3 Posters 1.1k Views 3 Watching
      MaryamR
      Hello everyone i have this 3D model on Sketchup, and i need to get the areas of diffrent faces using Ruby Sketchup API:
      For example :
      -for the first face on the left, i need to say that the face has a total area of 1.55 m² which is the area of the B face + the area of the A face, and say that this face has another face (A) in it and it's area is 0.06 m².
      And same for other faces (E and G).
      How can i find that the face B contains the face A and not C or D ? because all face have the same material and have random x,y,z coordinates.
      thank you in advance
        Let's take face A [ref as 'face'] and see what other faces are in it's plane and share edges etc.
        I assume that face A and face B have common edges - all other faces do not.
        loops = face.loops-[face.outer_loop] ### holes
        nested_faces=[]
        loops.each{|loop|
          nested_faces << loop.face ### filled in hole
        nested_faces.flatten!
        nested_faces.uniq!
        ### Now check which face[s] are in nested_faces...
        ### Should be B and no others...
          MaryamR
          thank you so much for your answer i'll try that
            MaryamR
            TIG i tried your method i used this code:
            model = Sketchup.active_model
              ents = model.active_entities
            ents.each do |f|
            if f.is_a? Sketchup;;Face
            loops = f.loops-[f.outer_loop]
            nested_faces=[]
            loops.each{|loop|
            nested_faces.uniq!
            for i in (0..nested_faces.length) do
            if nested_faces[i]!=nil
            UI.messagebox("face #{f.material.name} in face #{nested_faces[i].material.name}")
            but the messagebox shows :
            face B_material is in B_material
              face E_material is in E_material
              face G_material is in G_material
            but i want it to show :
            face A_material is in B_material
            so as to know both face B and A so that i can calculate the sum of their areas
            how can i do that ?
              Try this corrected code:
              model.active_entities.grep(Sketchup;;Face).each{|f|
              	f.loops
              	next unless f.loops[1] # skip faces without 'holes'
              	inner_loops = (f.loops - [f.outer_loop])
              	nested_faces = []
              	inner_loops.each{|loop|
              		loop.edges[0].faces.each{|e|
              			nested_faces << e unless e == f
              	nested_faces.each{|ff|
              		UI.messagebox("Face '#{ff.material.display_name}' [area=#{ff.area}]\ninside face '#{f.material.display_name}' [area=#{f.area}]\n[total-area=#{ff.area+f.area}]")
              puts
              The issue is with finding the loops correct face - see how I have now done it by getting the loop's first edge, then getting that edge's face[s], but excluding the 'host' face [f]...
              I have tested it and it works...
              PS:
              You might also want to check for the two faces having the same plane, and face.normal etc unless you can be sure that the faces are 2d and coplanar, and every edge has just one or two faces...
                MaryamR
                Hello TIG thnx for your answer.
                i didn't really understand this part:
                PS:
                did you meant that it will only work if the faces who contain other faces are in the same plane ? and not for faces who are in an other side ? like this image, in case of the blue face (face H) on the right it also has a face in it (face X) so would it create a problem as it's not in the same plane as the other faces ?
                  Like this...
                  • sdmitchS Offline
                    sdmitch
                    Face B will not be found on Face A because it is not defined by a "inner" loop.
                    http://sdmitch.blogspot.com/
                      Correct !
                      Let me modify the example so it truly fails...
                      A doughnut face A contains face B but face C is connected to B and A too by the Dual edge !
                        MaryamR
                        oh oky i understand now, thank you soo much this realy helped (y)
