π« Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
Scrapbook items too small in scrapbook window?
Is it possible to reduce the size of the white space on each scrapbook sheet?
I've got one setup with plants which have been scaled to be the correct size on at 1:50 on an A3 sheet.
The issue is that once they are this small, it's difficult to use the scrapbook window.
Hopefully the images explain it better!
Reduce the size of the sheet! If you open one of the default scrapbook pages you will notice they are 12" x 8.5" about A4 landscape!
Thanks!
