    Face Tilt
    10 Posts 3 Posters 1.4k Views 3 Watching
      MaryamR
      http://cdn2.tinyhousedesign.com/wp-content/uploads/2009/02/tiny-simple-house-2-450x406.png
      i'am new to Sketchup C/C++ SDK. I am creating a C/C++ program which gives me the geometry of a house model in Sketchup.I want to get the orientation of all the faces in the model and their Tilt. When I say the word 'Orientation' I mean to get the direction of every face relative to the N direction using the Axes in Sketchup and when i say Tilt i mean the degree of each face' tilt in the grey roof in this example.
      Can anyone come up with a solution or a method to do that?
      Thanks in advance
        Welcome
        Seems you have missed the Develpors section! πŸ˜‰
        http://sketchucation.com/forums/viewforum.php?f=180
          Welcome
          Seems you have missed the Develops forum section! πŸ˜‰
          • sdmitchS Offline
            sdmitch
            Thanks in advance
            For direction, are we talking about the clockwise or counter clockwise angle from North?
            Is tilt to be measured from vertical or horizontal.
            http://sdmitch.blogspot.com/
              MaryamR
              the tilt is to be measured from vertical i want to find the angle between the vertical line and the roof.
              'Orientation' I mean to get the direction of every face relative to the Red Axe, for example a face will have orientation of 90 degrees as it is perpendicular to the red axis.
              thank you
              • sdmitchS Offline
                sdmitch
                thank you
                In Sketchup, the red axis is East not North.
                That said, here is code that will give you the angles.
                mod = Sketchup.active_model
                ent = mod.active_entities
                sel = mod.selection
                faces = sel.grep(Sketchup;;Face)
                faces.each{|f|
                 if f.normal.z==0.0
                  ang=X_AXIS.angle_between(f.normal)
                 else
                  ang=Z_AXIS.angle_between(f.normal)
                 ent.add_text(Sketchup.format_angle(ang),f.bounds.center,f.normal)
                  MaryamR
                  thank you so much for your answer, this code works for C/C++ SDK in a C/C++ program or in Ruby ?
                  as i was all day finding just examples in Ruby and i've never used it before.
                  thnx
                  • sdmitchS Offline
                    sdmitch
                    thnx
                    Ruby only inside Sketchup I would guess.
                      MaryamR
                      i meant the code u suggested is it for Ruby or C/C++ SDK ?
                      • sdmitchS Offline
                        sdmitch
                        Ruby
