Sketchup 8
Hi everybody :
First, I'm using version 8. I have a couple of questions. One comment though. Too bad there wasn't a "converter" that could "convert" older version files to the newer file version. I AM thinking about switching to a newer version of Sketchup. Also, on the redering plugins, do any of them have "adjustable" settings. Such as settings for the amount of reflectivity (or shine)? And adjustable transparency ? The only other concern is that, I've always had problems getting the plugins installed and working. Thanks, garystan -
newer versions can open all previous versions, it's when you Save them they finalise the conversion...
john
@garystan said:
Hi everybody :
First, I'm using version 8. I have a couple of questions. One comment though. Too bad there wasn't a "converter" that could "convert" older version files to the newer file version. I AM thinking about switching to a newer version of Sketchup. Also, on the redering plugins, do any of them have "adjustable" settings. Such as settings for the amount of reflectivity (or shine)? And adjustable transparency ? The only other concern is that, I've always had problems getting the plugins installed and working. Thanks, garystan- As above, newer versions of SketchUp can automatically open files saved in older versions.
- Yes rendering plugins have all sorts of adjustable settings for materials and lighting.
- Try using the Sketchucation PluginStore software to find and manage plugins. There is also the SketchUp Extension Warehouse as a source. With newer versions of SketchUp you will find that the methods for installation have been enhanced, though the underlying mechanism is still the same (saving to the appropriate folder). Start from the beginning (as if you've not done it before) and read the instructions. There are sticky threads here as well.
Register LoginAdvertisement
