    Any way to have dimensions with MM and Inches together?
    3 Posts 2 Posters 327 Views 2 Watching
    • dereiD Offline
      derei
      Just wondering if is possible to have dimension lines in the same model that are NOT in the model's units.
      As an example, I needed to put some measurements in inches on a model built in millimeters (beside other dimensions that were in mm). Of course, there is always the possibility to edit the dimension line text, but I was wondering if it's possible to have it and keep the dimension linked.
      DESIGNER AND ARTIST DEREI.UK
      • BoxB Offline
        Tig again.
        http://sketchucation.com/pluginstore?pln=TIG_DualDims
        • dereiD Offline
          derei
          @box said:
          Tig again.
          It's a good plugin for batch editing units, but it also edits the text. Linked dims in other units than model units maybe are just not possible,
          Thank you for the link. It's useful.
