    Windows 10 Certain plugins make SU DISAPPEAR
    2 Posts 2 Posters 4.9k Views 2 Watching
    • BlastfurnaceB
      Blastfurnace
      Upgraded to windows 10 Pro
      SU 2016 PRO (But same results with 2015 PRO)
      I use a plugin called engineering toolbox. As soon as I open the extension there is a flicker and SU is GONE. No bugsplat. Nothing. just gone.
      So I removed all of the plugins from the plugin folder. I went to the extension warehouse, browsed to the Engineering toolbox plugin in the warehouse and just going to the warehouse page for Engineering toolbox, in the extension warehouse, made SU disappear again.
      So I tried other plugins pages in the warehouse. some came up fine and some cause Sketchup to just blink off. Skeng causes it to blink off too. As do others.
      I reinstalled Sketchup 2015 and have the same results with it.
      So what can be causing this behavior?
      Any tips? Thoughts? Solutions?
      thank you for your time.
      m
      • D
        driven
        a guess, without immediate solution...
        the ones that cause this try to take you away from the EW using a different protocol...
        i.e... http:// v https://
        supposedly it's all about keeping you secure...
        john
