    Dimension Export Error
    1 Posts 1 Posters 4.0k Views 1 Watching
    • D
      drewmorse
      Has anyone else run across this issue: I've created multiple dimensions using the API, but one of the dimensions doesn't export to DWG properly. I recreated the dimension in the Ruby console (see screenshot...it's the right-most selected dimension measuring 7.5625"). In the DWG export, this dimension shows as 0.0" and is oriented incorrectly even though in SketchUp it's oriented properly. Any ideas?
      This is the code used to generate the dimension in SketchUp...note the dimension shows up correctly.
      This is the result in DWG format.
