    Contour surface offset
    2 Posts 2 Posters 311 Views 2 Watching
    • A
      azz00
      Hi Everyone,
      I am currently trying to produce a 3D model of Sheffield City centre to be CNC milled this coming week.
      I have done everything including the site contours, buildings etc.
      However, I am struggling to find a solution to offsetting the roads by -0.5mm. Because the surface I have generated is a smooth contour, I cant find a way to cleanly pull the roads down?
      I have attached a link to the road layout so you can understand what I have so far.
      I have tried the joint push pull but it errors everytime. I am assuming that this is because the geometry is imported from Revit and theres something wrong with it?
      https://www.dropbox.com/s/c5hn5s9i4er6dhp/road%20layout.skp?dl=0
      Thanks for any advice!
        Pull down or offsetting ?
        That is not the same thing! πŸ˜„
        Scale * 1000
        Seems works with Projection by Didier Bur
        But you must repair some little gaps !
