    Lss_ToolBar2.0 beta 2 su2016 solution
    extensions
    1 Posts 1 Posters 825 Views 1 Watching
      DreamPsi
      Lss_toolbar Created by Krill btw. and its awesome... Puriod.
      I don't know if yall want to know but seeing how I spent all day trying to find out why my stick group function wasn't working in sketchup 2016 pro I came across the answer
      sketchup 2016 uses the newer version of ruby code. which makes the method to_a function not work unless you put it as lines.t_a first.
      so in the lss_mshstick.rb
      the problematic code is this
      line1078 @settings_hash["stick_vec"]=[@stick_vec.to_a.join(";"), "vector_str"]
      line1082 @settings_hash["bounce_vec"]=[@bounce_vec.to_a.join(";"), "vector_str"]
      the new fixed code is this
      line1078 @settings_hash["stick_vec"]=[@stick_vec.lines.to_a.join(";"), "vector_str"]
      line1082 @settings_hash["bounce_vec"]=[@bounce_vec.lines.to_a.join(";"), "vector_str"]
      so that fixed it for me though I'm still getting error msgs in the ruby console but its not affecting the function as far as I can tell.
      so hope this helps you guys
