    [?] Is there a plugin for this? [graduating color]
    12 Posts 6 Posters 1.1k Views 6 Watching
    • utilerU Offline
      utiler
      Hi guys, I want colour gradient across 2 or more colours in the Z axis and am wondering what's the best way to achieve this?
      I've tried Chris F's 'Color By Z' http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=16660 but doesn't seem to work on 2015.
      Also had a go at this one by Steve R http://sketchucation.com/forums/viewtopic.php?p=410416#p410416 but it shows up an error on opening SU...
      Any ideas?
      Just Curious...
        matteo
        Do you need a flat color on each face or can you use a texture?
        Maybe the SketchUV Mapping Tools http://sketchucation.com/plugin/960-dm_sketchuv is the right plugin.
        Can you post a screenshot of your model? to undestand better which plugin is better for you.
        hire me: http://www.nonsolo3d.it/ !
        • PixeroP Offline
          Pixero
          You could try projecting a gradient texture on to the geometry in one direction, X or Y.
          I used Fredos Thruepaint in this example.
          • utilerU Offline
            utiler
            Thanks for chiming in, guys. I don't really have a screenshot of what I want to do however the images in the 'gradientator' plugin is pretty much what I'd like to achieve although around a sphere. Say mid to dark green at the bottom and light up to a light green at the top.
            Just Curious...
            • soloS Offline
              solo
              Like this?
              http://www.solos-art.com
                Color By by Sdmitch ?
                • utilerU Offline
                  utiler
                  @solo said:
                  Like this?
                  [attachment=0:1qvos3et]<!-- ia0 -->Gradient.jpg<!-- ia0 -->[/attachment:1qvos3et]
                  Yes Pete!!! 😍 is that Color By SDMitch?
                  Cheers Pilou. 👍
                  Just Curious...
                  • utilerU Offline
                    utiler
                    Its a shame that 'Gradientator' doesn't work because that's pretty much what I need but I get an error on loading it.....
                    Just Curious...
                    • soloS Offline
                      solo
                      @utiler said:
                      @solo said:
                      Like this?
                      [attachment=0:7bpt1o79]<!-- ia0 -->Gradient.jpg<!-- ia0 -->[/attachment:7bpt1o79]
                      Cheers Pilou. 👍
                      That is just a gradient texture projected onto a sphere, want it?
                      • sdmitchS Offline
                        sdmitch
                        If you edit the Gradientator.rb file and remove the "@" above the "^" shown in the error message, the plugin will work. It is just a difference between Ruby 1.8 and Ruby 2.0.
                        However Gradientator only works based on a face's distance from the originGradiant1.jpg.
                        So you will need to rotate the sphere like this. Also, Gradientator only paints the front faces, so if you don't see the colors, select all and reverse the faces.
                        http://sdmitch.blogspot.com/
                        • utilerU Offline
                          utiler
                          I get it thanks Sam. I'll give it a go....
                          And I'll let you know if it doesn't Pete!
                          Just Curious...
                          • utilerU Offline
                            utiler
                            Silly, silly....
                            Chris Fullmer's 'Color by Z' is the simplest way to do this.....
                            Although so does Gradientator which offers an additiona color change.
                            Anyway got what I needed. Once again. thanks guys.!
                            Just Curious...
