    Solid works conversion
    3 Posts 3 Posters 1.1k Views 3 Watching
    • D
      deanlegg
      Hi all
      Is it possible to import solidworks files into SU?
      The files are easm and eapt
      Any help gratefully received
      Dean
      • FrederikF
        Frederik
        Yes, it's possible to import 3D files from SolidWorks...
        I'm not familiar with that format...
        The SolidWorks files I'm used to import is sldasm and sldprt...
        You can download SimLab Composer and with the free trial you can test it yourself...
        You also have the SolidWorks Importer for SU from SimLab Soft...
        Cheers
        Kim Frederik
        • D
          d12dozr
          Not directly. Third party software may be used to convert the file into something that Sketchup recognizes - like Frederik mentioned. Even better, if you have access to Solidworks, you can save the file as DWG (or DXF, STL, etc.), and import that file into Sketchup.
          If you don't have access to Solidworks to convert the file, feel free to PM me the files and I can help you.
          http://goo.gl/f7ooYh
