    How do I change the code?
    3 Posts 2 Posters 675 Views 2 Watching
      CEIT81729
      mod = Sketchup.active_model
      ent = mod.entities
      q = Sketchup.active_model.selection.add(
      Sketchup.active_model.definitions["aaa"].instances )
      a = Sketchup.active_model.selection.add(
      Sketchup.active_model.definitions["bbb"].instances )
      bb = Geom::BoundingBox.new.add(q.bounds.intersect(a.bounds))
      if bb.valid?
      puts "a"
      else
      puts "b"
      It can't run...
        Seems like you want to find the intersections of instances.
        First remember that the instances might be in different entities contexts...
        Using the selection is not always going to work as you expect...
        Better to get a list of the definitions' instances
        as = mod.definitions["aaa"].instances
        bs = mod.definitions["bbb"].instances
        now iterate one list and check intersections in the other.
        hits = {} ### empty hash
        as.each{|a|
          es = a.parent.entities
          hits[a]=[]
          bs.each{|b|
            next unless es = b.parent.entities ### same context
            bb = a.bounds.intersect(b.bounds)
            hits[a] << b if bb && bb.valid?
        hits.each{|hit| puts "AAA #{hit[0]} intersects BBB #{hit[1]}" }
          CEIT81729
          TO TIG:
          Thank you for your reply!
          If I want to get the component's dynamic attributes(lenx, leny...) by multiple components collision detection?
          and I will deduction of the overlapping area(multiple components) after...
          (1)multiple components collision detection
          (2)get the component's dynamic attributes(lenx, leny...)
          Thank you for your help!
