    DC Report
    5 Posts 2 Posters 3.0k Views 2 Watching
    • Phillip HP
      Phillip H
      Does anyone know? Is there anyway to get a report of the formulas in a DC? Obviously the native SU report generator (File>Generate Report...) only reports values, not formulas. Perhaps there is a plugin that might work?
      HP EliteBook 8440p Intel® Dual Core™ i7 M620@ 2.67 4GB RAM
      NVIDIA NVS 3100, 512 MB
      Windows® 8.1 64 bit
      SketchUp Pro 2015 version 15.3.331 64-bit
      • G
        Garry K
        I run this code on one of my doors
        ` model = Sketchup.active_model
        definitions = model.definitions
        definitions.each{ |defs|
        dicts = defs.attribute_dictionaries()
        next if dicts == nil
        dicts.each{ |dict|
        next if dict.name != 'dynamic_attributes'
        puts '', "dictionary: #{dict.name}, definition #{defs.name}"
        dict.each_pair{ |key, value|
        puts "key: #{key}, value: #{value}"
        dictionary: dynamic_attributes, definition 96 mm Wire Pull
        key: _description_label, value: Description
        key: _formatversion, value: 1.0
        key: _has_movetool_behaviors, value: 0.0
        key: _lastmodified, value: 2014-03-13 08:29
        key: _lengthunits, value: CENTIMETERS
        key: _name, value: 96 mm Wire Pull
        key: description, value: Cabinet Pull for 96 mm drilling
        dictionary: dynamic_attributes, definition Door#1
        key: _rotz_formula, value: angle
        key: angle, value: 0
        key: lenx, value: 40.0
        key: leny, value: 76.8
        key: lenz, value: 4.6
        key: name, value: Door#1
        key: onclick, value: animate("angle", 0, 120.0)
        • Phillip HP
          Phillip H
          dicts.each{ |dict|
          Garry, thank you. You are a lifesaver. This would make a nice little plugin. You should at least consider posting this in 'Code Snippets' in the developers forum. I'm sure it would be appreciated. 👍
          Windows® 8.1 64 bit
          • G
            Garry K
            Thanks Philip - my latest plugin is over 8000 lines of code.
            By comparison this just seems like an exercise.
            I saw your post and then I put threw this together from scratch.
            What I should say is this only works for component definitions which is what DC's are all about.
            You might want to also look at other dictionaries.
            • Phillip HP
              Phillip H
              Garry, you are too modest. Not taking away from your GREAT plugin GKWare Cabinet Maker, sometimes a short script is all that is needed to fill a void. There is nothing more valuable than the one that 'does the trick' when you need it.
              Most users are not coders. There is no equivalent native SU report. Dynamic Components are not that well documented for the new user. Your script (it needs a name) makes tracking and changing formulas in DCs much easier for us amateurs: we can paste results in any text editor and print what we need! It streamlines the learning process (priceless!). So again, for all of us that will benefit from this, thank you. You rock!
              Windows® 8.1 64 bit
