    [Plugin] [$] S4U Scale
    12 Posts 8 Posters 4.2k Views 8 Watching
    • hdpvH Offline
      hdpv
      S4u Scale
      Current version v2.0.1
      Scale Objects with reference points.
      Tab key : Scale uniform
      Trial and Purchase :
      http://extensions.sketchup.com/en/content/s4u-scale
      Or Trial:
      http://sketchucation.com/pluginstore?pln=s4u_Scale
      Suforyou
      http://www.sketchupforyou.com
        rv1974
        awesome!
          sancho77
          Cool!
          • F Offline
            function
            TAB for scale uniformly please and then I'm sold
            • hdpvH Offline
              hdpv
              For scale uniformly:
              -Select 2 points Min and Max of BoundingBox
              -Input : *numberscale or /numberscale (ex : *2 ,/3...)
              OR
              Press hold Shift and move Mouse.
              Use TAB for uniformly is the good idea.I will add this feature.
              Suforyou
              • olisheaO Offline
                olishea
                nice plugin
                oli
                • hdpvH Offline
                  hdpv
                  New feature : Tab key for Uniform scale was added.
                  Suforyou
                    Seems works also for Selection! (no group or no components) 😎
                    Can also be used for "Inverse" faces! 🤓 (if it's not a group/ component)
                    French Version linked! 😉
                    (verify for your name(s) file / folder : here it's just the file FR ! )
                    s4u_scale.zip
                    • hdpvH Offline
                      hdpv
                      Merci Pilou!
                      I added Français.
                      Suforyou
                      • hdpvH Offline
                        hdpv
                        Hi John!
                        It's possible for Group,Component but impossible for edges,faces.
                        I'm testing this if it's easy use i will add.
                        Suforyou
                        • JClementsJ Offline
                          JClements
                          Is scaling uniformly along just two axes relative to a specific point possible ?
                            chrishe
                            Hi, My licensing doesn't seem to work properly. I purchased it yesterday, but it keeps saying no license. Same in the "My Extensions" section. I already tried to reinstall.
                            I purchased a number of plugins, but this was my first purchase using the Extension Warehouse. I didn't use my google email address for purchase.. might that be a problem?
