    [Plugin] [$] S4U Scale
    12 Posts 8 Posters 4.7k Views 8 Watching
      sancho77
      Cool!
      • F Offline
        function
        TAB for scale uniformly please and then I'm sold
        • hdpvH Offline
          hdpv
          For scale uniformly:
          -Select 2 points Min and Max of BoundingBox
          -Input : *numberscale or /numberscale (ex : *2 ,/3...)
          OR
          Press hold Shift and move Mouse.
          Use TAB for uniformly is the good idea.I will add this feature.
          Suforyou
          http://www.sketchupforyou.com
          • olisheaO Offline
            olishea
            nice plugin
            oli
            • hdpvH Offline
              hdpv
              New feature : Tab key for Uniform scale was added.
              Suforyou
                Seems works also for Selection! (no group or no components) 😎
                Can also be used for "Inverse" faces! 🤓 (if it's not a group/ component)
                French Version linked! 😉
                (verify for your name(s) file / folder : here it's just the file FR ! )
                s4u_scale.zip
                • hdpvH Offline
                  hdpv
                  Merci Pilou!
                  I added Français.
                  Suforyou
                  • hdpvH Offline
                    hdpv
                    Hi John!
                    It's possible for Group,Component but impossible for edges,faces.
                    I'm testing this if it's easy use i will add.
                    Suforyou
                    • JClementsJ Offline
                      JClements
                      Is scaling uniformly along just two axes relative to a specific point possible ?
                        chrishe
                        Hi, My licensing doesn't seem to work properly. I purchased it yesterday, but it keeps saying no license. Same in the "My Extensions" section. I already tried to reinstall.
                        I purchased a number of plugins, but this was my first purchase using the Extension Warehouse. I didn't use my google email address for purchase.. might that be a problem?
