    First 3d print... couple of questions
    13 Posts 3 Posters 9.5k Views 3 Watching
    • marked001M Offline
      marked001
      So I'm having a simple (I think) print done for someone of their logo to be used as a holiday ornament. I extruded their logo and rounded the endges and I think all is ok?
      Since its going to be an ornament and needs a spot to hang, I added a small loop in the center of the model. Is this going to be an issue because it will end up being above the printing bed? I've got the loop in the center and the weight roughly looks like it will be even on any sides.. any thoughts on this? If anyone's got a better idea for the hanger, i'm certainly open.
      Let me know if you see any other issues. Thanks so much!
      http://www.revision21vis.com
      instagram: revi21on
      • cottyC Offline
        cotty
        The answer for your question depends on the printing technology. With a home printer, this hangover won't be a good idea I think. Is the head (?) itself to big to be the hanger?
        my SketchUp gallery
          marked001
          I dont think the 'head' is centered enough to be the hanger. In the second image, I posted the small loop that I had added.
          This is going to be sent to shapeways to get printed.
          instagram: revi21on
          • cottyC Offline
            cotty
            Which material? Strong and flexible will have no problem with that overhang...
            my SketchUp gallery
              marked001
              yes, strong and flexible is what i was thinking. haven't discussed with the client though.
              great! I will give it a shot.. appreciate the help guys.
              instagram: revi21on
              • olisheaO Offline
                olishea
                did you print this?
                the loop needs to be intersected with the model for it to be a solid....at the moment the loop looks separate to the model and is clipping the surface. Intersect and delete any internal geometry/faces. πŸ‘
                oli
                  marked001
                  Oli..it is intersected and I got rid of any conflicting geometry. But, the client said they wanted to just tie a ribbon around the center. They had 200 of them printed. When I get one in the mail, I'll snap a pic.
                  instagram: revi21on
                  • olisheaO Offline
                    olishea
                    Nice! It was hard to tell from the pics, I thought it was floating.
                    Which material did you settle for? Different colours? I'm well into 3D printing at the moment. πŸ˜„
                    Yes please share pics when you get one.
                    oli
                      marked001
                      I've been following along with what you've been doing. I'm slowly getting into it. Have a printer coming my way soon.
                      I think they just went with fast and flexible because they were getting alot of them. I'm a bit out of the loop because it was a client of a client. My client said they're a little wesk though and they probably should've used something else.
                      instagram: revi21on
                      • olisheaO Offline
                        olishea
                        Which printer are you going for? I'm looking at some myself...I don't expect the resolution to be amazing but need something good enough for prototypes. There are so many printers coming out it's hard to know what is going to remain current. Makerbot looks nice and simple but resolution isn't amazing.
                        oli
                          marked001
                          I rolled the dice on this: https://www.kickstarter.com/projects/tiko3d/tiko-the-unibody-3d-printer/description
                          It was cheap enough..
                          instagram: revi21on
                          • olisheaO Offline
                            olishea
                            Cheap enough i'd say! That's like ten times cheaper!! Looks great! Do you think they'll ship before xmas?
                            oli
                              marked001
                              I don't know. I was late to the game anyway so I was in the february group. First batch was supposed to be shipping now.. hopefully they're only a month behind.
                              instagram: revi21on
