    Flags for onMouseMove
    13 Posts 3 Posters 1.9k Views 3 Watching
    • fredo6F
      fredo6
      On Windows, the flags for Buttondown in the event onMouseMove is 1. So the test flags & 1 == 1 tells whether the button is down.
      Just to be sure, is it the same on Mac?
      Fredo
      • D
        driven
        does this help?
        onMouseMove; flags = 256
        onLButtonDown; flags = 258
        onLButtonUp; flags = 256
        onRButtonDown; flags = 264
        onRButtonUp; flags = 256
        onMouseMove; flags = 264
        # misses the up but changes to move flag
        • S
          slbaumgartner
          On Mac the flags are a (undocumented in SU) bit-map. Experimentally, 10 (2 decimal) is left button, 1000 (8 decimal) is right button. It's never been clear to me what they meant you do to with a bit-map that isn't documented!
          • fredo6F
            fredo6
            Actually, I need the value of flags, for the onMouseMove method when the Left button is down.
            Apparently nothing that has a bit value of 1.
            Fredo
            • D
              driven
              Fredo, the flags were in there, the flag is 258...
              onMouseMove; flags = 258  #left down starts here
              onMouseMove; flags = 256  #left down released here
              Key Tool Deactivated.
              • fredo6F
                fredo6
                Thanks very much
                On Windows, the bitmask logic for onMouseMove is:
                • Left button down -> 1 (i.e. flags & 1 == 1)
                • Shift down -> 4
                • Ctrl down -> 8
                • Alt down -> 32
                  This logic also applies to onLButtonDown (alwasy contains 1) and onLButtonUp
                On Mac, the bitmask logic seems different. The flags always include 256, and the button and modifiers are adding to that:
                • Left button down -> 2 (i.e. flags & 2 == 2)
                • Shift down -> ?
                • Ctrl down -> ?
                • Alt down -> ?
                John: would be kind to check what are the value of flags for the 3 modifiers. Also, check the flags on the methods onLButtonDown and onLButtonUp to see if they respect the logic too.
                Fred
                • D
                  driven
                  hi Fredo it's not so straight forward...
                  there are two ways to get RButtonDown on a mac and I think they have different flags...
                  but every mouse in the house has one fault or another...
                  this one has a broken RButton...
                  I'll update when I fix or buy a new mouse...
                  Key Tool Activated.
                  256 = onMouseMove
                  "LButtonDown"
                  258 = onMouseMove with onLButtonDown
                  "LButtonUP"
                  onKeyDown; Key code; 262144 ( VK_CONTROL )
                  "RButtonDown"
                  262409 = onMouseMove with onRButtonDown using control LButton
                  onKeyUp  ; Key code; 262144 ( VK_CONTROL )
                  264 = onMouseMove with onRButtonDown
                  256 = onMouseMove
                  onKeyDown; Key code; 524288 ( VK_ALT or VK_MENU )
                  "LButtonDown"
                  524578 = onMouseMove with onLButtonDown with modifier
                  "LButtonUP"
                  524576 = onMouseMove with onRButtonDown using control LButton
                  onKeyUp  ; Key code; 524288 ( VK_ALT or VK_MENU )
                  onKeyDown; Key code; 1048576 ( VK_COMMAND )
                  "LButtonDown"
                  1048842 = onMouseMove with onLButtonDown with modifier
                  1310987 = onMouseMove with onLButtonDown with modifier
                  onKeyUp  ; Key code; 1048576 ( VK_COMMAND )
                  "LButtonUP"
                  • S
                    slbaumgartner
                    Here's my output from a modified version of the event reporter John was using. It covers all the combinations of mouse moves with one or both buttons pressed as well as any of the four modifier keys. I added printout of the hex and decimal values of the flags because I find that easier to understand than trying to subtract the decimal values all the time.
                    Key Tool Activated.
                    "MouseMove"
                    Flags;      256 (0X000100 = 0b000000000000000000000100000000)
                    "LButtonDown"
                    "MouseMove"
                    Flags;      258 (0X000102 = 0b000000000000000000000100000010)
                    "LButtonUP"
                    "RButtonDown"
                    "MouseMove"
                    Flags;      264 (0X000108 = 0b000000000000000000000100001000)
                    "LButtonDown"
                    "RButtonDown"
                    "MouseMove"
                    Flags;      266 (0X00010A = 0b000000000000000000000100001010)
                    "LButtonUP"
                    onKeyDown; Key code; 131072 ( VK_SHIFT or CONSTRAIN_MODIFIER_KEY or CONSTRAIN_MODIFIER_MASK )
                    "MouseMove"
                    Flags;   131328 (0X020100 = 0b000000000000100000000100000000)
                    onKeyUp  ; Key code; 131072 ( VK_SHIFT or CONSTRAIN_MODIFIER_KEY or CONSTRAIN_MODIFIER_MASK )
                    "MouseMove"
                    Flags;   262401 (0X040101 = 0b000000000001000000000100000001)
                    onKeyDown; Key code; 524288 ( VK_ALT or VK_MENU or COPY_MODIFIER_KEY or COPY_MODIFIER_MASK )
                    "MouseMove"
                    Flags;   524576 (0X080120 = 0b000000000010000000000100100000)
                    onKeyUp  ; Key code; 524288 ( VK_ALT or VK_MENU or COPY_MODIFIER_KEY or COPY_MODIFIER_MASK )
                    onKeyDown; Key code; 1048576 ( VK_COMMAND or ALT_MODIFIER_KEY or ALT_MODIFIER_MASK )
                    "MouseMove"
                    Flags;  1048840 (0X100108 = 0b000000000100000000000100001000)
                    onKeyUp  ; Key code; 1048576 ( VK_COMMAND or ALT_MODIFIER_KEY or ALT_MODIFIER_MASK )
                    "LButtonDown"
                    "MouseMove"
                    Flags;   131330 (0X020102 = 0b000000000000100000000100000010)
                    "LButtonUP"
                    "RButtonDown"
                    "MouseMove"
                    Flags;   262409 (0X040109 = 0b000000000001000000000100001001)
                    "LButtonDown"
                    "MouseMove"
                    Flags;   524586 (0X08012A = 0b000000000010000000000100101010)
                    "LButtonUP"
                    "LButtonDown"
                    "MouseMove"
                    Flags;  1048842 (0X10010A = 0b000000000100000000000100001010)
                    "LButtonUP"
                    "RButtonDown"
                    "MouseMove"
                    Flags;   131336 (0X020108 = 0b000000000000100000000100001000)
                    "RButtonDown"
                    "MouseMove"
                    "RButtonDown"
                    "MouseMove"
                    Flags;   524584 (0X080128 = 0b000000000010000000000100101000)
                    "RButtonDown"
                    "MouseMove"
                    "LButtonDown"
                    "RButtonDown"
                    "MouseMove"
                    Flags;   131338 (0X02010A = 0b000000000000100000000100001010)
                    "LButtonUP"
                    "RButtonDown"
                    "RButtonDown"
                    "MouseMove"
                    "LButtonDown"
                    "RButtonDown"
                    "MouseMove"
                    "LButtonUP"
                    "LButtonDown"
                    "RButtonDown"
                    "MouseMove"
                    "LButtonUP"
                    • fredo6F
                      fredo6
                      @slbaumgartner
                      Thanks. Very helpful.
                      Then it means that a portable flag decoding for onMouseMove could be
                      #Flags for onMouseMove
                      if (RUBY_PLATFORM =~ /darwin/i)
                         def buttonLDown?(flags) ; flags & 2 == 2 ; end
                         def shiftDown?(flags) ; flags & VK_SHIFT == VK_SHIFT ; end
                         def ctrlDown?(flags) ; flags & VK_CONTROL == VK_CONTROL ; end
                         def altDown?(flags) ; flags & VK_ALT == VK_ALT ; end
                      else
                         def buttonLDown?(flags) ; flags & 1 == 1 ; end
                         def shiftDown?(flags) ; flags & 4 == 4 ; end
                         def ctrlDown?(flags) ; flags & 8 == 8 ; end
                         def altDown?(flags) ; flags & 32 == 32 ; end
                      • D
                        driven
                        fredo,
                        you probably don't want to use VK_CONTROL on a mac...
                        256 = onMouseMove
                        258 = onMouseMove with LButtonDown
                        131072 ( VK_SHIFT )
                        131330 = onMouseMove with LButtonDown and ( VK_SHIFT )
                        524288 ( VK_ALT )
                        524578 = onMouseMove with LButtonDown and ( VK_ALT )
                        1048842 = onMouseMove with onLButtonDown and ( VK_COMMAND )
                        Usage example from Move Tool:
                        Shift = Lock move to the current inference direction ( VK_SHIFT )
                        Option = Toggles copy of selection ( VK_ALT )
                        Command =Toggles autofold of selection ( VK_COMMAND )
                        Control behaves differently depending on the order it is chosen...
                        262403 = onMouseMove with LButtonDown THEN ( VK_CONTROL )
                        OR
                        262409 = onMouseMove with ( VK_CONTROL ) THEN LButtonDown
                        ( VK_CONTROL ) THEN LButtonDown will show a context menu...
                        LButtonDown THEN ( VK_CONTROL ) will NOT...
                        john
                        • fredo6F
                          fredo6
                          Thanks again.
                          Then, with some luck, the following portable code should make it on PC and Mac
                          def buttonLDown?(flags) ; flags & MK_LBUTTON == MK_LBUTTON ; end
                          def shiftDown?(flags) ; flags & CONSTRAIN_MODIFIER_MASK == CONSTRAIN_MODIFIER_MASK ; end   #shift
                          def ctrlDown?(flags) ; flags & COPY_MODIFIER_MASK == COPY_MODIFIER_MASK ; end              #Ctrl (PC) or Command (Mac)
                          def altDown?(flags) ; flags & ALT_MODIFIER_MASK == ALT_MODIFIER_MASK ; end                 #Alt (PC) or Ctrl(Mac)
                          Fredo
                          • D
                            driven
                            write a test with some puts and I'll test it...
                            john
                            • fredo6F
                              fredo6
                              john
                              Thanks in advance. I thought initially that the question was resolved somewhere in the forum, but could not find it (and it is anyway not described in the SU API doc).
                              Fredo
