    [Plugin] Entity Info + 0.2.0
    12 Posts 6 Posters 4.8k Views 6 Watching
    • TommyKT Offline
      TommyK
      Provides a window to quickly view and edit the selected entities' properties. Works like the Entity Info with a user customisable set of attributes to edit. Future versions will include more properties.
      Download from the Plugin Store
      The intention of this tool is to allow users to productively and quickly review and add data to the model.
      Usage: Window > Entity Info +
      I would welcome feedback on:
      • what component attributes you would like to manipulate in a future release.
      Thanks to Guy for initial coding.
      Release Notes
      v 0.1.1
      • Fixed for Windows - now works on both PC ad Mac (sorry guys)
      v 0.2.0 - alpha release
      • Renamed plugin to "Entity Info +" which is describes its intention better
      • New user customisable list of entity properties
      • New properties available
      • Classifications can be edited, although this is early days at the moment, with lots of bugs
      • New system for adding properties allows developer contributions
      • JQLJ Offline
        JQL
        I'd use it very often if I could batch assign these settings:
        • Glue/Unglue - Vertical, Horizontal, Slopped;
        • Cut openning;
        • Face Camera;
        • Shadows Face Sun.
        • Lock/unlock;
        • Assign all components/groups to a family name; For instance if Family=Window; Every Unique component in the selection would be renamed to "Window#1", "Window#2" etc... No component should be changed to "Window" without havign a sequential numbering.
        • Select all components from a family;
        • Select all component instances;
        • Replace all component instances;
        • Save As;
        • Batch Save As (using folder and component name)
        • Reload;
        • Batch reload...
        • Set axis without having to edit the component;
        • Draw guide points at bounding box;
        Is it asking too much? πŸ˜„
        www.casca.pt
        Visit us on facebook!
        • G Offline
          greatoe
          but where to download this?
          • P Offline
            Pherim
            Plugin Store.
              Jim
              Thanks Tommy - it does not work on Windows. The dialog opens, but the fields are always empty regardless of the selection. I will have a look to see what i can find.
              • TommyKT Offline
                TommyK
                Thanks Jim, I will load up windows on my very old machine to see what I can do!
                • Cut openning;
                • Face Camera;
                • Shadows Face Sun.
                • Lock/unlock;
                • Save As;
                • Reload;
                • Batch reload...
                Wow, that is a long list! I am considering a customisable system, where the user can add/remove the attributes that are important to them, so I don't think it is too much. I think the following properties on your list is manageable, and would be in the scope of what I am trying to achieve in this plugin:
                • Cut openning;
                • Face Camera;
                • Shadows Face Sun.
                • Lock/unlock;
                • Save As;
                • Reload;
                The following, though I think would be better served by another plugin.
                • Batch reload...
                • TommyKT Offline
                  TommyK
                  Thanks for the update. I have now fixed it. There was a rogue console.log() call in the webDialog window markup that was breaking javascript. It took me ages to figure out what was going on - as soon as I loaded the firebug javascript debugger - it started working!)
                    Jim
                    Yep, it's working now. Thanks.
                    I did change the path where the extensions looks for the html dialog, though. The change allows me to install the plugin in folders other than the default Plugins folder:
                    # html_path = Sketchup.find_support_file "SelectionWindow.html" ,"Plugins/SelectionAttributes/"
                    html_path = File.join(File.dirname(__FILE__), "SelectionWindow.html")
                    • TommyKT Offline
                      TommyK
                      Plugin has been updated. This is still an alpha release, but there are big improvements.
                      Release Notes
                      v 0.2.0
                      Developer Contributions Welcome
                      There is a dizzying array of potential properties that can be edited in SketchUp, which will take a lot of coding to complete. I have developed a way to organise each property in this plugin, so developers (myself included) will be able to write just 4 methods (propertyName, get, set, validate) for each property that they wish to add to the mix.
                      If you are interested, have a look at the propertyType.rb file in the plugin, and see if you can't write the code needed to get your favourite property into the plugin. I will be happy to review and integrate contributions.
                        ### EXAMPLE ###
                        # Each new property type needs to define 4 methods as in the example below.
                        # Note that all methods are class methods, so it can be called without creating
                        # an instance of the class.
                        # The first method simply defines the name of the property type, and the name of
                        # the 'get', 'set' and 'validate' methods it uses.
                        def self.example
                            # getNameFunc is an optional variable, which builds the name from parameters
                            #passed to the method.  This is required for property types such as atributes,
                            # which need to include the attribute dictionaries and attribute label in the name
                            values = {'name' => 'example', \
                            'label' => 'Example', \
                            'getNameFunc' => 'exampleName', \
                            'getValueFunc' => 'getExample', \
                            'setValueFunc' => 'setExample', \
                            'validateFunc' => 'validateExample'}
                          return values
                        def self.exampleName(options)
                          name = 'example;' + options.to_s
                          return name
                        # The get method takes a Sketchup;;Selection object, and any parameters required.
                        # Parameters are required when getting deeper structured information about attributes
                        # or Classifications, for example.
                        # Params;
                        # +selection+;; Sketchup;;Selection object from which to get the values from.
                        # +params+;;  Additional parameters required to get the value (optional).
                        def self.getExample(selection, params)
                          result = {}
                          result['label'] = 'example' # the label shown to the user (optional - defaults to existing label)
                          result['hidden'] = false  # if true, the input box on the editor window will be hidden (optional - defaults to false)
                          result['message'] = "This is a message, not that you need it" # this shows the help text that can be displayed on the editor window (optional)
                          result['warning'] = "Watch out" # a warning to be displayed prominently to the user next to the label text (optional)
                          result['value'] = selection[0].definition.description # the output value. Can be a string, or an array of result objects with the same values as above (required)
                          result['form-type'] = 'text' # the form type, can be 'text', 'textarea', 'checkbox', 'select'
                          return result
                        # The set method sets the property of the selection.
                        # Params;
                        # +selection+;; Sketchup;;Selection object to which we can apply the properties.
                        # +params+;;  The values to set the property with.
                        def self.setExample(selection, params)
                          if selection.length > 0
                            # Make your edits here
                            stuff = params['value'] # values normally reside in this hash
                            params['success'] = true # mark your values as successfully set
                            return params # return the params
                          else
                            params['success'] = false # report that something went wrong
                            params['warning'] = "something went wrong" # optional message to be displayed to the user
                        # The validate method validates the input parameters, and amends them if necessary.
                        # Params;
                        # +selection+;; Sketchup;;Selection object to which the properties are to be applied.
                        # +params+;;  A hash object containing values.
                        def self.validateExample(selection, params)
                          if params['value'] == "oh no" # check for problems with values
                            params['error'] = true # report an error - this will stop the setting of the property
                            params['warning'] = "Value given is not a string" # optional message to be displayed to the user
                          return params # return the parameters for the next step; set the property.
                      • K Offline
                        kiwi15
                        Hi TommyK,
                        This new way is indeed a much better way to tweak component properties. Apparently you are not the only one who have found the native Component Browser cumbersome: https://extensions.sketchup.com/en/content/component-properties
                        Thanks for a cool and promising plugin:)
                        • JQLJ Offline
                          JQL
                          I use that Thomthom's plugin everyday as it's way easier than using component browser for just those glue properties and the likes. However it doesn't work with multiple components...
                          www.casca.pt
                          • TommyKT Offline
                            TommyK
                            @kiwi15 said:
                            Hi TommyK,
                            Thanks, kiwi. Yes ThomThom's plugin is indeed worth mentioning in this thread.
                            I must admit I have other distractions at the moment, so development on this is slow. Glue properties are high on my list for this plugin.
