    Load errors
    3 Posts 2 Posters 383 Views 2 Watching
    • A
      architect
      I get this window on startup and would like to clean up whatever is causing it.
      Running Sketchup Pro 8 on a Mac OS 10.6.8
      load errors.pdf
      • A
        Anton_S
        I suspect that it is caused by SketchyPhysics. Based on the paths provided by the load error, SketchyPhysics was extracted improperly. Instead of putting SketchyPhysics3 folder and SketchyPhysics.rb file into the plugins folder, you probably relocated all the content within the SketchyPhysics3 folder right into the plugins folder, which is incorrect. To remove that error, you should remove all content in your plugins folder that is related to SketchyPhysics. Identify which files and folders belong to SketchyPhysics and erase them. Identify files by downloading new SketchyPhysics and removing all files and folders within the plugins folder that are matching with the content in the newly downloaded SketchyPhysics3 folder. You may also simply delete the whole plugins folder if you don't have much useful plugins there and reinstall SketchyPhysics properly.
        • A
          architect
          Thanks Anton that took care of it.
