    Import dwg elements to Layer0
    14 Posts 6 Posters 989 Views 6 Watching
    • pbacotP Offline
      When importing dwg files, all the elements come in on their CAD layer. Is there any way to get them to go to layer0 ? Ideally the blocks would go onto their layers OR a layer based on the elements, but all raw geometry would go to Layer0. But I would not mind if objects AND blocks all went to Layer0--its better than nothing.
      The plugin "default layer geometry" is helpful but it is VERY slow and sometimes it is unclear if it has "hung"--meaning I hate waiting indefinitely. Fixing the layers after is not working therefore.
      • sdmitchS Offline
        sdmitch
        To put everything on Layer0, open the Entity Info window. Select everything then choose Layer0 in the Entity Info window.
        To put all loose geometry on Layer0
        Sketchup.active_model.active_entities.each{|e|
         next if e.is_a?(Sketchup;;Group)||e.is_a?(Sketchup;;ComponentInstance)
         e.layer='Layer0'
        http://sdmitch.blogspot.com/
        • pbacotP Offline
          Thanks! Everything is components--which is helpful (you never know until you start working with the import) so it can be a lot of work to drill down to the raw geometry and place it on Layer0. I'll try your script and see if it is faster.
          • pbacotP Offline
            I select the component and paste the script in ruby console. Nothing happens. The console returns:
            #<Sketchup;;Entities;0x007fde7b0884a8>
              driven
              @pbacot said:
              I select the component and paste the script in ruby console. Nothing happens...
              Sam's script works on raw geometry...
              This one should drill down and gives a countdown as Status Text, so you know it's working...
              Tig's plugin is probably better and may be faster...
              # move to Layer0
              t1 = Time.now
              model = Sketchup.active_model
              defs = model.definitions
              grps_comps =[]
              defs.each{|d|
                          next if d.image?
                          ins=[]
                          d.instances.each{|i|ins << i.name}
                          grps_comps << d.instances unless ins.empty?
              draw_elements = []
              count = 0
              grps_comps.each{|c| draw_elements << [c[0].definition.entities.find_all{|e| e.valid?}] }
              model.start_operation("move to 0")
              draw_elements.flatten!.each{|e|  count+=1
                              e.layer='Layer0'  rescue next
                              Sketchup;;set_status_text((" #{count} of #{draw_elements.length}" ),SB_PROMPT)
              # break if count == 10
                model.commit_operation
              puts Time.now - t1
              john
              • sdmitchS Offline
                sdmitch
                Sorry, I took raw geometry to mean all entities not in a group or component. Also, the script works on the model not a selection.
                Since this is an import, I would assume that all definitions exist because at least one instance was created during the import process. Therefore, you should only need to modify the layer of the entities in the definition which will automatically redefine each instance.
                So, again for the model and not a selection
                Sketchup.active_model.definitions.each{|cd|cd.entities.each{|e|e.layer='Layer0'}}
                • pbacotP Offline
                  Thanks! This seems to be working, but seems to have the same problem as "default layer" plugin. Taking a long time. I am running it while I have breakfast and see what happens. Wish there were a right way to use dwg files. SU is really behind in all aspects of working with these files.
                    driven
                    @pbacot said:
                    ...Taking a long time...
                    it took about 18 minutes to do 297345 edges/faces in my test file...
                    the problem is it has to find every one and move them one at a time...
                    you could run it in the background and work on a different instance of SU, on a different model...
                    I do that sometime when rendering, like they can on a PC...
                    john
                    • cottyC Offline
                      cotty
                      Maybe (?) TIGs LayerWatcher can help here too?
                      http://sketchucation.com/plugin/1496-tig_layerwatcher
                      my SketchUp gallery
                      • BoxB Offline
                        No doubt cleaning up the DWG before import would help.
                        • pbacotP Offline
                          It took something like about that long.
                          I have times when I am importing my own work in dwg and I can do some things beforehand. How do you "cleanup" objects being on LayerO? with blocks on assigned layers in CAD? You can't really, if your CAD doesn't support that.
                          What would be best is that blocks keep their layers and entities import at layerO, just like SketchUp is supposed to be used. However the opposite is how SU makes imports.
                          The case I am working on is cleaning up someone file that was given to me. The third scenario is receiving a cad file from another source to import. Part of the "cleanup" should be automatic.
                          If one is just going to give up on the imported layers (for blocks-components) then the fastest thing to do is just delete the imported layers. Entities then go to Layer0 instantaneously.
                            driven
                            Peter, if you PM me an example 'layered' dxf, there is an idea i would like to try...
                            may come to nothing...
                            john
                            • srxS Offline
                              srx
                              Have you try to import using FreeDXF plugin? It does great job with layers.
                              www.saurus.rs
                              • pbacotP Offline
                                No I haven't tried that plugin. I'll take a look. Usually I receive dwg files but I can ask for DXF. Peter
