    How to make toolbar in method(def..end) has parameters
    9 Posts 3 Posters 2.0k Views 3 Watching
    • C
      CEIT81729
      Hello everyone:
      I want to know how to make toolbar in method(def..end) has parameters
      e.g.
      def slab(valueq)
      path = File.dirname(FILE) + "/image/"
      menu = UI.menu("Plugins").add_submenu("xx")
      toolbar = UI::Toolbar.new("xx")
      command = UI::Command.new("ss") {slab}
      command.small_icon = command.large_icon = path + "/slab.png"
      command.tooltip = command.status_bar_text = "s"
      menu.add_item command
      toolbar.add_item command
      toolbar.show
      Thank you for your answer!
      • M
        MSP_Greg
        Using instance variables
        def slab(var1, ..., varN)
        command = UI;;Command.new("ss") { |@var1, ..., @varN| slab(@var1, ..., @varN) }
        Greg
        • C
          CEIT81729
          Sorry...Greg
          I try to use instance variables like this:
          def slab(valueq)
          command = UI::Command.new("ss") { |@valueq| slab(@valueq) }
          but ruby editor shows the situation like this":
          cannot be an instance variable
          and...if I change the code like this:
          def slab(valueq)
          command = UI::Command.new("ss") { |valueq| slab(valueq) }
          toolbar.show
          Error: #<TypeError: no implicit conversion of NameError into String>
          It seems to be...undefined local variable or method ‘menu’ and ‘toolbar’ for command...
          Situation1
          Situation2
          • M
            MSP_Greg
            Try the following (class variable just in case...)
            @@valueq = 1
            def slab(valueq)
              puts "valueq = #{valueq}"
            # below is for testing
            command = UI;;Command.new("ss") { slab(@@valueq) ; @@valueq += 1 }
            # normal line is below, as before
            # command = UI;;Command.new("ss") { slab(@@valueq) }
            toolbar.show
            As you click the icon, you should see valueq increment each time.
            Note, inside of braces/blocks, the || are only used when the calling code has parameters to pass. Command.new doesn't do that. Methods like .each (and others) do...
            Greg
            • C
              CEIT81729
              Greg, I'm sorry because I tried it or not successful...
              then, I think in this way, use "class...end"
              the code like this:
              class SphereTool
              def slab(valueq)
              sphere_cmd = UI::Command.new("Sphere") {
              Sketchup.active_model.select_tool SphereTool.new
              sphere_cmd.small_icon = "sphere_small.gif"
              sphere_cmd.large_icon = "sphere_large.gif"
              sphere_cmd.tooltip = "Create a sphere"
              sphere_toolbar = UI::Toolbar.new "Sphere"
              sphere_toolbar.add_item sphere_cmd
              sphere_toolbar.show
              but it shows...
              "Nil result (no result returned or run failed)"
              Error: #<NoMethodError: undefined method slab' for #<AS_RubyEditor::RubyEditor:0x00000007e1cad8>> (eval):76:in block (2 levels) in initialize'
              SketchUp:1:in `call'
              class...end
              • TIGT
                def self.slab(valueq=nil) ### what is 'valueq' ?
                OR PERHAPS
                def initialize(valueq=nil) ### run by 'class.new()'
                  slab(valueq)
                  ### OR move all of the slab code into here ??
                AND remember to pass a ' valueq' to the tool, otherwise you'll get an error if it's nil ?
                • C
                  CEIT81729
                  To TIG:
                  "valueq" is the argument I entered through Webdialog
                  by WebDialog (JavaScript pass value) to the ruby
                  I try to packaged this slab code with Class or Method(def...end)
                  and click the button to be able to run the code
                  but it seems problems in pass value and convert argument
                  • TIGT
                    @ceit81729 said:
                    To TIG:
                    OK.
                    So do NOT include it as an argument for any methods.
                    Put the tool into the menu thus.
                    sphere_cmd = UI::Command.new("Sphere") { Sketchup.active_model.select_tool(SphereTool.new()) }
                    This will ' new' will initialize the tool.
                    Normally you include so variable defaulting etc in the def initialize() method.
                    As you have a tool the 'activate' [or 'reactivate'] methods will set up some variables and kick off the processes: perhaps opening a dialog to take in settings and then changing a @status variable's value so the mouse tools click in to place something etc...
                    If you are using a webdialog it needs to setup callback, which returns some value[s] to the Ruby-side.
                    Pass these into the callback {} block.
                    Values will be strings so you need to convert them to floats or lengths as appropriate.
                    Set these values to be an instance-variable like @valueq which can be read by all methods within the same class.
                    If you want to remember it across uses of the class then use @@valeq - you need to set up as a class-variable @@valueq=1.23 [or any logical default value!] made inside the class, but outside of any methods, so that it's created for future use as the class is initially defined.
                    This way next time the class is re-run the value is remembered from the previous time.
                    Then, after the @@/@valueq is set up by the callback, run the method slab() or self.slab() [depending on how you have coded it].
                    Within the 'slab' code use @/@@valueq and it'll be taken as the value the callback set - even though that was within a separate method.
                    There are several kinds of 'variables' - here let's assume you use the name 'valueq'
                    A plain-variable - valueq - which is used only in that def method - it's always lower-case and starts [a-z] and can only contain letters, numbers and an _
                    An instance-variable - @valueq - which is used/seen/set through a Module's methods and its value will persist across uses, or when used in a Class, but for one use - these variables can also be accessed from outside the Module etc if set up properly with code like attr_reader :valueq etc.
                    A class-variable - @@valueq - like an @var but its value persists across uses of a Class.
                    There is also a 'Constant' which you must initially set up within the Module/Class, but outside any methods - Valueq or more traditionally VALUEQ [and it always starts with an uppercase A-Z]. You should never change this later - although you can it will produce a disconcerting Ruby Console 'warning'. Note how Ruby/SketchUp use Constants for unchanging references like [ruby:16pk0se5]ORIGIN[/ruby:16pk0se5] and [ruby:16pk0se5]Z_AXIS[/ruby:16pk0se5]. It behaves like a read-only @@var...
                    And finally there's the 'global' variable - [ruby:16pk0se5]$valueq[/ruby:16pk0se5] - which is accessible to/by ALL Methods/Modules/Classes - even those you have not written - BUT you should NEVER use these - it's sure to one day clash with somebody else's poorly set up code !
                    Other variable types do everything you'll need...
                    I include them for information only.
                    Note how Ruby/SketchUp does use some Globals like [ruby:16pk0se5]$:[/ruby:16pk0se5] or [ruby:16pk0se5]$LOAD_PATH[/ruby:16pk0se5] etc to store globally accessible info, but you do NOT need to do so...
                    • C
                      CEIT81729
                      Thanks for everybody help and advice 👍
                      The problem has been resolved 😄
