    Mustang Mach 1 1971
    16 Posts 7 Posters 1.2k Views 7 Watching
    • cheddaC Offline
      chedda
      Mustang Mach 1 1971 Sketchup & Maxwell Render
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • tademaT Offline
        tadema
        Nice one Simon πŸ‘ great looking car although the overall image looks a little dull (dark), maybe my daft monitor though.
        John
        • cheddaC Offline
          chedda
          Yes it needs some highlights, i will add some car lights πŸ˜‰ I think some of the detail is lost in compression here as well.
          • JQLJ Offline
            JQL
            It looks great as usual! It might be a bit dark yes but I think if the light could focus more in the car, darkness would work out well. (You also seem to have an inverted heigth map on the wall...)
            www.casca.pt
            Visit us on facebook!
            • DanielD Offline
              Daniel
              I almost mistook it for a photograph.
              My avatar is an anachronism.
              • jujuJ Offline
                juju
                have a look here and try the renderer...
                http://www.indigorenderer.com/image-galleries/vehicles
                • cheddaC Offline
                  chedda
                  http://www.maxwellrender.com/index.php/gallery/images/2/1/584
                  http://www.maxwellrender.com/index.php/gallery/images/2/2/448
                  πŸ˜‰
                  • JQLJ Offline
                    JQL
                    Bah Simon, that triumph is uncanny... not fair!
                    www.casca.pt
                    • hellnbakH Offline
                      hellnbak
                      Nice, but one thing I always like to know - which parts did you model and which are from the Warehouse or some other source?
                        Another fine result, I would still go for a European type sports car but your render shows the Mustang in the best possible light. Pun intended.
                        • cheddaC Offline
                          chedda
                          This is an updated version of the image with a few more highlights and some more "pop". I ordered this car from Humster 3D they even modified it to suit the exact model i needed. The car is part of a much bigger project I'm working on. Here are some clues:
                          Regarding the scene the back wall and floor textures are from cgtextures. The bins and fire escape are from the warehouse. I used the ivy maker plugin for the ivy and the other plants (can you identify them ?) are from an artist on deviant art.
                          I made the casino sign component using an image from a google search.I traced the sign & letters and then used the pipe along path plugin to create the tubes. This component i then used behind the camera x 3 along with a vegas image converted to HDR for the reflections. The grass in the cracks i made by roughly tracing the image and then using component spray to distribute the grass proxies along the lines and intersections.
                          I used the Kodak Gold 200 film response inside Maxwell render no post work.
                          I think the image now has a bit more life Tadema ? πŸ˜‰
                          • JQLJ Offline
                            JQL
                            Yes it has more life but the focus got away from the car a bit. It's still great but I think the first was even better.
                            The light coming from the car is cool, but do you think some light that would be focused the car more would ruin it?
                            www.casca.pt
                            • cheddaC Offline
                              chedda
                              I wouldn't like any theatrical lighting to be honest plus any sources would show in reflections. I'm happy enough for now.
                              • JQLJ Offline
                                JQL
                                I understand and I like your position!
                                www.casca.pt
                                • tademaT Offline
                                  tadema
                                  Phew for a second I thought you had landed the part as the next Bond πŸ˜† James Bond !
                                  Looks great and has a lot of atmosphere πŸ‘ .
                                  The problem with rendering older cars is people expect the paint to be as now which wasn't the case, modern cars are lacquered with a high gloss finish (sometimes with a metallic flake finish). It's very easy to make (flat) gloss paint look like plastic if you overdo the reflection and I think you've cracked it here.
                                  John
                                  • cheddaC Offline
                                    chedda
                                    Yes i agree car paint is a bit of a black art. Maxwell has a car paint procedural which allows tuning of metallic and gloss. However the base colour you select often shifts wildly under render because of the technical manner of the material.
