    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • medeekM
      medeek
      Version 3.4.1 - 04.18.2024
      • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.4.2 - 04.23.2024
        • Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
        design.medeek.com
        • medeekM
          medeek
          Version 3.4.3 - 04.30.2024
          • Added ceiling gypsum for tray and coffer trusses.
          • Enabled the "Edit Truss Assembly" function for tray and coffer trusses (imperial and metric units).
          • Enabled labels for tray and coffer trusses.
          • Updated the license verification system with a more secure and improved algorithm.
          http://design.medeek.com/resources/trussplugin/images4/truss_su822_800.jpg
          design.medeek.com
          Reply Quote 2
          • medeekM
            medeek
            [b]Version 3.4.4[/b] - 05.02.2024
            • Added ceiling gypsum for cambered and mono cathedral trusses.
            • Enabled the “Edit Truss Assembly” function for cambered and mono cathedral trusses (imperial and metric units).
            • Enabled labels for cambered and mono cathedral trusses.
            • Fixed some minor bugs for mono cathedral trusses.
            alt text
            alt text
            design.medeek.com
            • medeekM
              medeek
              Version 3.4.5 - 05.10.2024
              • Enabled ceiling insulation for shed rafter roofs: Batt, Blown-in.
              • Enabled ceiling insulation for gable rafter roofs: Batt, Blown-in.
              • Enabled ceiling insulation for hip rafter roofs: Batt, Blown-in.
              • Enabled the "Edit Truss Assembly" function for all flat trusses (imperial and metric units).
              alt text
              alt text
              alt text
              alt text
              alt text
              design.medeek.com
              gullfoG 1 Reply Last reply
              • gullfoG
                gullfo @medeek
                @medeek -- no spray foam? 🙂 actually, probably changing the material on the rafter insulation (first image) would probably represent.
                Glenn
                http://www.runnel.com
                • medeekM
                  medeek
                  Version 3.4.6 - 05.16.2024
                  • Enabled sheathing, cladding, ridge cap and labels for dual pitch trusses.
                  • Updated the polynesian truss so layers and materials are properly assigned.
                  • Enabled the "Edit Truss Assembly" function for dual pitch trusses (imperial and metric units).
                  • Enabled the "Edit Truss Assembly" function for polynesian trusses (imperial and metric units).
                  • Enabled the "Edit Truss Assembly" function for bowstring trusses (imperial and metric units).
                  • Enabled the "Edit Truss Assembly" function for bow barrel trusses (imperial and metric units).
                  http://design.medeek.com/resources/trussplugin/images4/truss_su830_800.jpg
                  The edit and regen functions have now been enabled for all active truss types within the plugin.  However I still have four truss types that need to be setup and activated.
                  design.medeek.com
                  • medeekM
                    medeek
                    I now have the basic system in place and working for the rafter roofs but if you look closely you can see there is still some refinement necessary. The example shown is two gable rafter roofs that are connected, with the trimming of the primary roof limited to only framing, cladding, gutters and soffit/fascia. Note that the insulation, gypsum, rafters and sheathing is not trimmed on the primary roof:
                    alt text
                    alt text
                    alt text
                    The tricky part with the refinement is how best to generate the cutting solid to subtract away the unwanted portions of the roof(s). Currently the way I am doing it is using the hidden roof primitive and the roof outline. I basically take the roof outline, extrude it vertically down and then union this solid with the roof primitive above. The resulting solid is then used to subtract against the geometry of any attached roofs. This seems to work reasonably well in most cases but as you can see with the soffit and fascia (and the gutters) there is some overlapping and other minor complications. The insulation also gets a little carved out in places but it is mostly acceptable.
                    alt text
                    alt text
                    alt text
                    Thoughts or suggestions?
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.4.7 - 05.23.2024
                      • Enabled Roof Connections between complex roofs, rafter roofs, truss roofs and solid groups.
                      • Added the "Configure Roof Connection" feature to the edit menu for complex, rafter and truss roofs.
                      This is not a completely new feature however the configuration capability introduced (and the level of granularity achievable) is new and somewhat experimental at this point. I'm sure it will take a few updates and versions before all the issues are worked out and all the necessary refinement is achieved.
                      Also note that that not all rafter roofs and not all truss types have this feature enabled yet. The following rafter roofs have been enabled:
                      • Gable
                      • Shed
                      • Shed w/ Ledger
                      The following truss types have been enabled:
                      • Common
                      • Monopitch
                      • Scissor
                      • Attic
                      • Tail Bearing
                      • Symmetric Cathedral
                      • Cathedral
                      • Parallel Chord
                      More to come soon...
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.4.8 - 05.25.2024
                        • Enabled Roof Connections for the following additional truss types: tray, monocathedral, cambered, monoscissor and coffer.
                        • Enabled Roof Connections for hip and dutch gable rafter roofs.
                        • Enabled the "Edit Roof Assembly" function for dutch gable rafter roofs (imperial and metric units).
                        • Enabled the following 3D roof cladding material for dutch gable rafter roofs: Metal.
                        alt text
                        alt text
                        design.medeek.com
                        • medeekM
                          medeek
                          Tutorial 30: General Roof Connections (16:54 min.)
                          Please email me any feedback or suggestions on this new feature.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.5.0 - 05.26.2024
                            • Enabled "flat" ceiling gypsum for dutch gable rafter roofs.
                            • Enabled "flat" ceiling gypsum for hip rafter roofs.
                            • Fixed a bug with the global settings for rafter and truss roofs when the layer/tags option is turned off.
                            alt text
                            alt text
                            CRITICAL BUG FIX!
                            Version 3.4.7 introduced a bug for both rafter and truss roofs when the layers/tags option is turned off. This release fixes that bug. I highly recommend that everyone download this latest update to correct this bug.
                            design.medeek.com
                            Reply Quote 2
                            • medeekM
                              medeek
                              [b]Version 3.5.2[/b] - 05.30.2024
                              • Enabled ceiling insulation for floor trusses: Batt, Blown-in.
                              • Enabled ceiling insulation for I-Joist and Lumber floors: Batt, Blown-in.
                              • Fixed a bug with ceiling gypsum for inset floors (I-joist and Lumber).
                              • Fixed a minor bug with joist hangers for common lumber sizes for inset floors.
                              http://design.medeek.com/resources/trussplugin/images5/truss_su853_800.jpg
                              http://design.medeek.com/resources/trussplugin/images5/truss_su852_800.jpg
                              http://design.medeek.com/resources/trussplugin/images5/truss_su851_800.jpg
                              Honestly I didn't want to spend too much time updating this module since the new Floor plugin will supersede it, however since I do intend on retaining it within the Truss plugin for the foreseeable future, I thought it best to bring it up to speed with the other truss assemblies, and add the insulation option.
                              Some of these updates seem small now and very incremental however they all take time and energy and they usually involve fairly tedious updates to the attribute library code and the HTML menus.
                              The Truss plugin overall probably still has the most work that needs to be done of all the plugins. Compared to the Wall plugin this plugin has many partially finished tools and features and still certain trusses that are missing advanced options. The work will go on.
                              design.medeek.com
                              • gullfoG
                                gullfo @medeek
                                @medeek thanks! when do you expect to drop the new floor plugin? 🙂
                                Glenn
                                • medeekM
                                  medeek
                                  Version 3.5.3 - 06.09.2024
                                  • Enabled a feature to selectively remove specific trusses from floor truss assemblies.
                                  • Enabled a feature to selectively remove specific joists from I-joist and lumber floor assemblies.
                                  https://global.discourse-cdn.com/sketchup/original/3X/6/2/62cc073888d0cfecbea99e04bb25931977baa3cf.jpeg
                                  https://global.discourse-cdn.com/sketchup/optimized/3X/1/2/12ac1d4971166805986aecd30609d1c3e66215cc_2_690x453.jpeg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.5.4 - 06.15.2024
                                    • Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs.
                                    !! Critical Bug Fix !!
                                    Note that this bug only reveals itself if you have the sub-fascia for the truss or rafter roof turned off. This bug applies to both truss and rafter roofs (gable).
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.5.5 - 06.22.2024
                                      • Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs (when adv. roof options disabled).
                                      This bug only reveals itself if you turn off the advanced roof options. The bug applies to truss and rafter roofs. I highly recommend updating to this latest version.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        The new Rafter Roof menu should be a bit more visual and intuitive for selecting the appropriate roof type:
                                        design.medeek.com
                                        Reply Quote 2
                                        • medeekM
                                          medeek
                                          Version 3.5.6 - 07.03.2024
                                          • Enabled a graphical user interface for Rafter Roof selection.
                                          • Enabled a graphical user interface for Floor selection.
                                          • Fixed a bug introduced in Version 3.5.3 for all I-joist, lumber and truss floors (when adv. floor options disabled).
                                          design.medeek.com
                                          Reply Quote 2
                                          • medeekM
                                            medeek
                                            Version 3.5.7 - 07.05.2024
                                            • Fixed a bug for all rafter roofs that have glulam beams.
                                            design.medeek.com
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 74 / 77
