    LibFredo6 Installation Error.
    extensions
    1 Posts 1 Posters 1.2k Views 1 Watching
    • C
      ChadWade
      I am finally getting back to cleaning up my 2015 Sketchup install on Windows 10 so I can actually use all the plugins that I have in the past. Yeah I am a little behind, Kids...
      I installed many plugins from the sketchucation toolbar, extension warehouse, etc. with success. I have installed the required LibFredo6 supplement, I think 6.8. It seems to be working fine with all the Fredo6 plugins, except Tool on Surface. I cannot get that one to install and it causes the following error.
      Error Loading File Fredo6_!LibFredo6.rb
      Error; #<ArgumentError; invalid byte sequence in UTF-8>
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;716;in `match'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;716;in `block (2 levels) in load_from_config'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;715;in `each'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;715;in `block in load_from_config'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;713;in `foreach'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;713;in `load_from_config'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;1099;in `block in load_all_plugins'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;1099;in `each'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;1099;in `load_all_plugins'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;786;in `load_from_config'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb;188;in `startup'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb;338;in `<module;LibFredo6>'
      C;/Users/user/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb;34;in `<top (required)>'
      I have tried removing all the Fredo6 items in the identified location and reinstalled with the same results. Would someone point me towards a fix. I am at a loss.
      Thank you in advance.
