    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 484.4k Views 71 Watching
    • G Offline
      Garry K
      CabMaker follows System 32 as closely as possible. System 32 is designed this way on purpose to allow the stacking of cabinets while maintaining proper Door Gaps.
      A cabinet uses this calculation for door size.
      Door Width = (Cabinet Width - (Door Count * Door Gap)) / Door Count.
      Door Height = Cabinet Height - Door Gap
      Notice that the wording is "Adjust Top Gap". This is not an override - it is an adjustment. This value is added to the Door Gap to produce the overall gap. So if you have a door gap of 3 mm and a value of 12 mm for "Adjust Top Gap" then the result is 15 mm.
      Also notice that CabMaker calls it Drawer Spacing - not Drawer Heights. This again is for adopters of true system 32. My default metric cabinet values in my examples have height as 768 mm and drawer spacing of 160 mm. It isn't coincidence that these values divide by 32. 768 / 32 = 24 and likewise 160 / 32 = 5.
      I added "Adjust Top Gap" as a feature on request by a number of users. I also added "Adjust Bottom Gap" for the same reason. Additionally a number of users asked to extend doors below the bottom of upper cabinets so I modified the "Adjust Bottom Gap" to give you the ability to put in a negative value.
      I will add this to the list of feature requests to modify "Adjust Top Gap" to allow negative values. When enough users request a feature then that feature moves up the list.
        abdalmalki
        Thank you Garry for the detailed explanation.
        Regarding doors can extend below the bottom of upper cabinets, it would be nice if you add light rail to the cabmaker:
        • G Offline
          Garry K
          Version 1.0.39 just about ready.
          • Network path not working. Fixed
          • Materials with Capitals in name created a problem. Fixed
          • Gave Tall cabinets their own tab. Each tall cabinet section now has its own settings
          • Upper tall cabinets had a bug where doors on top and mid sections were not lined up. Fixed
          • Tall cabinets now can have doors in bottom section.
          • Tall cabinets bottom section can now have shelves and pullouts or dividers
          Essentially the bottom section now works the same as for any standard cabinet. All the settings on the first page apply to the bottom section of a tall cabinet. The Top and Mid sections now have there own areas resulting in less confusion.
          Notice that you can have 3 different door styles and a different drawer style on 1 tall cabinet.
          You can also have up to 4 different handles. The Top section defaults to Upper defaults and the Mid Section defaults to Base defaults.
          The Top section can have shelves and or pullouts or vertical dividers. The Mid section behaves as before by setting the mid sections configuration.
          • G Offline
            Garry K
            You were asking about an Ikea cabinet a few postings back.
            On Cabinets Tab:
            Height = 40"
            Depth = 16"
            Cabinet Type = Upper
            Cabinet Style = Base
            Drawers = 0
            Doors = 1
            Hinge Top
            On Tall Cabinets Tab:
            Top Section:
            Height = 20"
            Doors = 1
            Hinge Top
            Shelf = 1
            Mid Section:
            Height = 0"
            • G Offline
              Garry K
              I am doing a fairly thorough testing of the Tall Cabinets. So many permutations and combinations that it is taking longer than I originally anticipated.
              There are 7 section combinations Times 6 constructions Times 3 for uppers, base integrated and base non integrated.
              That's 142 combinations and doesn't even begin to deal with different types of interiors.
              Here is a model containing 24 different tall cabinets. The 3 rows on the right are uppers, integrated base, and non integrated base. The six columns on the right represent 6 constructions.
              The six cabainets on the left (2 rows of 3) represent 1 construction for base cabinets with integrated kick
              These tests have uncovered a few Face Frame bugs that you can visually see. The cabinets with 1 and with 2 sections show correct top gap but only the cabinets that have the bottom section have correct bottom gap. Additionally one cabinet has rendered incorrectly.
              So ... testing continues.
              • G Offline
                Garry K
                Version 1.0.39 is now ready to download.
                Available from my web site or from Sketchucation.
                • G Offline
                  Garry K
                  If you want to have a shared location for templates and library files there is a way. I created a shared location on a different drive and then set up a batch file to point to that location.
                  One reason to do this is if you have several licensed computers and you want to have 1 set of templates. Another reason is you want to make sure your templates don't get over written during an update.
                  From the command prompt
                  subst x: e:\library\gkware_cabmaker
                  Then copy the following files into the shared area
                  Next from the main menu choose
                  Extensions\GKWare_CabMaker\Cab Maker - Edit Config
                  And set the library location to x:
                  Finally restart sketchup for the changes to take effect.
                  • G Offline
                    Garry K
                    I spent another 2 days testing and found a few more errors in the tall cabinets.
                    Now pretty happy with the test suite. The skp test file is 7 megs and contains 90 tall cabinets of various constructions and configurations.
                    Version 1.0.40
                    • some configurations for frame less overlay construction for tall cabinets had the doors in the bottom section incorrect heights. fixed
                    • the auto drawer size feature was not properly updating the drawer height. fixed
                    • when using auto drawer size the drawer box height was inconsistent. fixed
                    • For Overlay doors only the top Gap can be now be eliminated by setting the value to negative door gap.
                    Here are the 90 tall cabinets
                    • G Offline
                      Garry K
                      Version 1.0.40 now ready for download
                      • G Offline
                        Garry K
                        1.0.41 ready for download
                        Version 1.0.41 - Mar 30, 2016
                        • Side dado's incorrect for Base cabinets with Integrated Kick with a 0 notch and side dadoes. Fixed
                        • Sink cabinets with side dado and rule to omit top had top dado. Top dado should be skipped. Fixed
                        • Parts report sometimes missing a part. Fixed
                        • Added new parts report for Gold. *_full_part_list.csv
                        • Added configuration setting for 'Silent Permissions'
                        • Update manual and added lines to translation files
                        • G Offline
                          Garry K
                          I am working on a new way to choose a cabinet from the library for those of you who want to work with libraries.
                          The idea is to add a find button, then pop up a new window that contains pictures of your cabinets. There would be a bit of work on your part.
                          What does everyone think?
                            abdalmalki
                            Garry,
                            I think it will consume a lot of your time without big advantage to the software.
                            That's my two cents.
                            • G Offline
                              Garry K
                              Version 1.0.42
                              • Added Confirm Save Configuration and a confirm popup to Web Dialog.
                              • Added context sensitive help for cabinet templates. If 320 X 240 png image exists in library folder
                              • Added version number to web dialog title
                              • Side by Side drawers now work for frameless construction and stretchers set to at least 1
                              • You now have option for edging upper cabinet ends of the sides if not skinning the top and or bottom
                              • Corner cabinet adjustable shelving had edging along the back where the shelf butts up against the corner brace. Fixed
                              • Sides, Top and Bottom front edges had edging with face frame construction. Fixed
                              • You can override shelf spacing for up to 3 shelves
                              • You can now set pullout spacing for up to 3 pullouts or use the default rule
                              • Cabinets with 1 door set to pullout now works with more than 1 pullout
                              • G Offline
                                Garry K
                                You can set the openings (space between shelves) and (space between pullouts) here
                                You can have different shelf width adjustments for Uppers and Base cabinets and have 2 widths for shelves for base cabinets. Also you can edge the ends of sides - bottom, top, none or both.
                                Set the new values to -1 to disable
                                Here is the change for multiple pullouts with a door.
                                Here are split sink shelves - you set the length - set to -1 to disable.
                                • G Offline
                                  Garry K
                                  Version 1.0.42 is now ready for download
                                  • G Offline
                                    Garry K
                                    Added pigeon hole capability using vertical dividers and horizontal dividers. Works with frameless or face frame construction and for uppers or base cabinets.
                                    This can work as a wine rack.
                                    • utilerU Offline
                                      utiler
                                      Looks like my wine rack, Garry...
                                      Always empty. šŸ˜•
                                      Just Curious...
                                      • G Offline
                                        Garry K
                                        Andrew - mine too. Someone suggested that I have to buy it faster than I drink it!
                                        In actuality one of my hobbies is making wine. We live in wine country in British Columbia Canada. I do have a cool dark cellar and a metal wine rack that stores bottles 30 per shelf. Each shelf holds 8 bottles on the first row, 7 on the second row etc.
                                        Wine ages best in a cool dark place. The advantage of having the bottles touch each other in this way is that it is suppose to reduce the effect of small temperature fluctuations.
                                        • G Offline
                                          Garry K
                                          Version 1.0.43 will be ready today for download
                                          • Added horizontal grid along with vertical dividers. Can use as a wine rack.
                                          • Modified the web dialog materials tab. Colors now show on a empty label just to the left of the color pulldown.
                                          • Modified web dialog. When Mac users use arrow keys in a closed drop down the graphics now update like it does for Windows users.
                                          • G Offline
                                            Garry K
                                            Version 1.0.43 ready for download
                                            Next I am looking at adding a right and left angled cabinet. This style of cabinet is for finishing a run of cabinets.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
