    Select Construction Points - inside groups
    7 Posts 3 Posters 614 Views 3 Watching
    • cmeedC Offline
      cmeed
      Hello All
      Is there a way to select everything and then only select construction points. So when I say select everything - all my geometry is neatly in hundreds of groups within groups etc.
      I used 'pipe along path' many times and forgot to turn the cpoints off (although they were extremely helpful for placing etc so I kind of needed them) I went to take a quick 'Plan', I zoomed out and realised my mistake, when all the cpoints are noticeable and detract from the main information I need to convey
      so I would like to put them on new layer and be able to turn them off.
      or
      is there a visual setting ?
      cheers in advance
      Chris
      • cottyC Offline
        cotty
        Yes, with Thomthoms selection tools, but only for the curent context.
        @cmeed said:
        or is there a visual setting ?
        Yes, uncheck "Guides" in the view menu, cpoints are guides too.
        my SketchUp gallery
        • cmeedC Offline
          cmeed
          Great thank you.
          So no plugin that can dig into groups?
            Do you really still need those cpoints? Why not just use edit>Delete Guides and get rid of them altogether?
            • cmeedC Offline
              cmeed
              Cotty - So After years and Years of using Sketchup I never knew about view menu-guides! ---- DOH!
              Dave - So After years and Years of using Sketchup I never knew about Edit menu- delete guides! ---- DOH!DOH!
                I set up a keyboard shortcut for Edit>Delete Guides. Once they've done their job, it's silly to keep them as they just clutter the drawing space. And just making them not visible by editing the style isn't a solution because you have to turn them back on when you need to use guides the next time.
                • cmeedC Offline
                  cmeed
                  ok good advice - cheers thats sorted
                  c
