    Rotate Selection
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    1 Posts 1 Posters 7.2k Views 1 Watching
    • heyitsmekyleH
      heyitsmekyle
      Often I'll need to rotate a group/annotation inside of layout, and the only way is to select the object, then drag the rotational 'handle' to make it rotate.
      If there was a menu item that was activated when a group was selected, I could set up a hotkey (like in sketchup) that allows me to rotate the item - this would speed things up a bit and make it less frustrating to use layout.
      Sincerely,
      Kyle Marsh
