    Link Component Attributes to IFC Text fields
    3 Posts 2 Posters 2.9k Views 2 Watching
      stefanocendron
      I'm looking for a way to link the Component Attributes Text (that changes depending on the component behaviour in the model) to the IFC Text that is possible to fill from the Component Options Window. Is there any trick / code / snippet to make this work? or is this something really complex to achieve?
      Thanks,
      Stefano
      here's the concept: IFC text automatically referring to the Component Attributes.
        Jim
        The core code would look like this: Assume there is a single Component selected.
            model = Sketchup.active_model
            instance = model.selection[0]
            attributes = instance.definition.attribute_dictionary("dynamic_attributes")
            name = attributes["name"]
            desc = attributes["description"]
            path = ["IFC 2x3", "IfcFurnishingElement", "Name", "IfcLabel"]
            success = instance.definition.set_classification_value(path, name)
            path = ["IFC 2x3", "IfcFurnishingElement", "Description", "IfcText"]
            success = instance.definition.set_classification_value(path, desc)
          Jim
          It's unclear to me how the plugin would know to use "IfcFurnishingElement" as the type in the path. There does not appear to be any way to retrieving this type using a plugin. So I'm stumped.
