    DC Component into DC component
    3 Posts 2 Posters 1.8k Views 2 Watching
    • MALAISEM
      MALAISE
      HI Everybody
      I'm sweating on setting the following DC Object.
      Is_it possible to set a sub Dynamic component inside a DC parent without making it
      standalone ?
       Let see the file. I would like to be able to "select" position on the cylinder which
      is a "child" from Theta  ( Cristaux"1)whereas the Theta and 2Theta are running.
      Thanks a lot
      part of a goniometer
      • G
        Garry K
        Here is an example of a DC component that uses nesting.
        Please note that the door still works if you make a mirror copy.
        nested bifold
        • MALAISEM
          MALAISE
          Hi Gary
          Thanks for your help.
          I've found a solution. Please just play with the file.
          Explanation: 2Theta is changed into a sub component of Theta, then I considered Theta component as parent...then I can click on cristals to change the position, while the goniometer is turning.Sub DC 2 component.skp
          Have a look on the drafty modification.
          Cheers
          Pierre
