    3D PDF ( SimLab) and Dynamic component
    7 Posts 3 Posters 2.5k Views 3 Watching
    • MALAISEM
      MALAISE
      Hello Everybody
      Has anyone experienced Dynamic components exported into 3D PDF ?
      Is it possible ?
      Pierre
      • FrederikF
        Frederik
        I assume that you're asking if the dynamic actions will transfer to the 3D PDF, when using SimLab - right...?
        Unfortunately they don't...
        However, it also makes sense as the "Interact with dynamic components" pointer is something only SU is capable of, hence it's not something Acrobat Reader is able to...
        The only thing you can do is to create camera views in SimLab, which will get exported to the 3D PDF document...
        I've attached a sample I just made...
        In SU you can open the doors, the trunk and hood and more - but these don't work in the PDF...
        SimLab-Dynamic-test.pdf
        Cheers
        Kim Frederik
          Simple dynamic components works fine in LightUp ! 😉
          I have not tested if the animation exported in luca format accept this "Dynamic Component" animation! (hard disc burned) 😢
          Edit : works! It's writed in the manual! (page 54)
          (format who permit to any user who have not Sketchup and/or Lightup to interact with the animation rendered) ! 😎
          French manual of Dynamic components inside LightUp 😉
          • FrederikF
            Frederik
            As a PDF document...?!?
            From the video you've posted as well as the manual you've posted a link to, I don't see that it's converted to a 3D PDF document, which is what the OP asked for...
            Can you please elaborate, Pilou...??
            Cheers
            Kim Frederik
            • MALAISEM
              MALAISE
              Hi Frederik and Pilou
              Effectively, I didn't find solution, as far as Dynamic component is SketchUp internal property.
              Thanks for help.
              Cheers
              Pierre
                Of course that don't make a real PDF 3D but that is a "PDF 3D like" for the user and better!
                • possibility to walk through inside a rendered file + Dynamic Components working!
                • MALAISEM
                  MALAISE
                  Pilou,
                  I try this way. ; )
                  Pierre
