    Why does the servo not rotate more than +/-180 in sketchyphy
    14 Posts 2 Posters 9.7k Views 2 Watching
    • Y Offline
      youthreewire
      Hello,
      I am trying to command a hinge to act as a servo for +360 and -360 degrees but there is a problom. Just as he servo crosses +180 or -180 it starts to continuously rotate at very high speeds. Can I set these limits software in the plugin (I know that we can set the servo max and min in the UI of sketchy physics but it does not work for more that +/-180 deg). Please tell me how shall I change these limits and where to change these limits or is it hard coded in the Newton dynamics (the physics engine that sketchy physics uses) dll or what ever.Please some one let me know.
        Anton_S
        I tried configuring servo before, but never got to work properly over 180 degrees. Although, you can use a motor joint and control it with script to achieve something that works even better than sp servo joint.
        • Y Offline
          youthreewire
          Motor joint has velocity control but how to incorporate position control in a motor joint in sketchyphysics is not known. I think we need to modify it in the scripts some where or the newton physics dll to allow for more that 180 deg rotation. Anyone.. any more ideas?
            Anton_S
            Yeah, that would be great, but we don't have C++ source code to do that. We only have the Ruby source code, but it doesn't contain the code that tells how a servo should work. Most if not all the physics engine related code is within the C++ source which we don't have access to.
            Yet, it is possible to tell the motor to adjust itself to a desired angle. I will upload an example tomorrow. That said, we can also create a custom servo joint in new SP release that bases of a motor joint trough some ruby scripting.
            • Y Offline
              youthreewire
              Also I dont see any proportional controller for the motor in the sketchy physics ruby files. I think Newton server takes care of this and I am guessing if we need the servo to move more than 180 we need to change this in the newton dynamics engine.
              • Y Offline
                youthreewire
                This if possible would be great.I will wait for this from you.
                • Y Offline
                  youthreewire
                  I think if we can read angle from a motor and put a proportional controller then we can integrate velocity or use the angle and impose control.
                    Anton_S
                    You're correct! Here is an example:
                    motor-servo.skp
                    Use W,S virtual keys to control desired angle. The motor will then rotate the arrow to the desired angle.
                    • Y Offline
                      youthreewire
                      Impressive...Thanks
                      • Y Offline
                        youthreewire
                        Hello,
                        I have been trying to control the motor you scripted through a slider but I want to do an extend range control.The slider value varies only between 0.0 and 1.0 .I want to do a control like -5.0 to 5.0 with the slider.How shall I change the limits of the slider?
                          Anton_S
                          There are two ways of doing it:
                          1. Change slider min/max parameters. Set slider controller to:
                            slider("range_control", 0, -5, 5)
                          2. Take the current slider ratio, subtract 0.5 from it, and multiply it by 10:
                            (slider("range_control") - 0.5) * 10
                          • Y Offline
                            youthreewire
                            Earlier I wrote an API to control the servos from C code.That was working well with sketchup 7 with sketchyphysics 3.2. The example you gave uses the latest version of sketchup and runs in sketchup 8 for me but my C API does not work with sketchy physics 3.5.9. So can you give me the same example with google sketchup 7 running sketchyphysics 3.2 .Please.
                              Anton_S
                              Here is a SP3.2 compatible example:
                              motor-servo.skp
                              • Y Offline
                                youthreewire
                                Thanks I will give it a try and let you know about my progress.
