    Why does the servo not rotate more than +/-180 in sketchyphy
    14 Posts 2 Posters 9.9k Views 2 Watching
      Anton_S
      I tried configuring servo before, but never got to work properly over 180 degrees. Although, you can use a motor joint and control it with script to achieve something that works even better than sp servo joint.
      • Y Offline
        youthreewire
        Motor joint has velocity control but how to incorporate position control in a motor joint in sketchyphysics is not known. I think we need to modify it in the scripts some where or the newton physics dll to allow for more that 180 deg rotation. Anyone.. any more ideas?
          Anton_S
          Yeah, that would be great, but we don't have C++ source code to do that. We only have the Ruby source code, but it doesn't contain the code that tells how a servo should work. Most if not all the physics engine related code is within the C++ source which we don't have access to.
          Yet, it is possible to tell the motor to adjust itself to a desired angle. I will upload an example tomorrow. That said, we can also create a custom servo joint in new SP release that bases of a motor joint trough some ruby scripting.
          • Y Offline
            youthreewire
            Also I dont see any proportional controller for the motor in the sketchy physics ruby files. I think Newton server takes care of this and I am guessing if we need the servo to move more than 180 we need to change this in the newton dynamics engine.
            • Y Offline
              youthreewire
              This if possible would be great.I will wait for this from you.
              • Y Offline
                youthreewire
                I think if we can read angle from a motor and put a proportional controller then we can integrate velocity or use the angle and impose control.
                  Anton_S
                  You're correct! Here is an example:
                  motor-servo.skp
                  Use W,S virtual keys to control desired angle. The motor will then rotate the arrow to the desired angle.
                  • Y Offline
                    youthreewire
                    Impressive...Thanks
                    • Y Offline
                      youthreewire
                      Hello,
                      I have been trying to control the motor you scripted through a slider but I want to do an extend range control.The slider value varies only between 0.0 and 1.0 .I want to do a control like -5.0 to 5.0 with the slider.How shall I change the limits of the slider?
                        Anton_S
                        There are two ways of doing it:
                        1. Change slider min/max parameters. Set slider controller to:
                          slider("range_control", 0, -5, 5)
                        2. Take the current slider ratio, subtract 0.5 from it, and multiply it by 10:
                          (slider("range_control") - 0.5) * 10
                        • Y Offline
                          youthreewire
                          Earlier I wrote an API to control the servos from C code.That was working well with sketchup 7 with sketchyphysics 3.2. The example you gave uses the latest version of sketchup and runs in sketchup 8 for me but my C API does not work with sketchy physics 3.5.9. So can you give me the same example with google sketchup 7 running sketchyphysics 3.2 .Please.
                            Anton_S
                            Here is a SP3.2 compatible example:
                            motor-servo.skp
                            • Y Offline
                              youthreewire
                              Thanks I will give it a try and let you know about my progress.
