    Why does the servo not rotate more than +/-180 in sketchyphy
    14 Posts 2 Posters 10.1k Views 2 Watching
      Anton_S
      Yeah, that would be great, but we don't have C++ source code to do that. We only have the Ruby source code, but it doesn't contain the code that tells how a servo should work. Most if not all the physics engine related code is within the C++ source which we don't have access to.
      Yet, it is possible to tell the motor to adjust itself to a desired angle. I will upload an example tomorrow. That said, we can also create a custom servo joint in new SP release that bases of a motor joint trough some ruby scripting.
      • Y
        youthreewire
        Also I dont see any proportional controller for the motor in the sketchy physics ruby files. I think Newton server takes care of this and I am guessing if we need the servo to move more than 180 we need to change this in the newton dynamics engine.
        • Y
          youthreewire
          This if possible would be great.I will wait for this from you.
          • Y
            youthreewire
            I think if we can read angle from a motor and put a proportional controller then we can integrate velocity or use the angle and impose control.
              Anton_S
              You're correct! Here is an example:
              motor-servo.skp
              Use W,S virtual keys to control desired angle. The motor will then rotate the arrow to the desired angle.
              • Y
                youthreewire
                Impressive...Thanks
                • Y
                  youthreewire
                  Hello,
                  I have been trying to control the motor you scripted through a slider but I want to do an extend range control.The slider value varies only between 0.0 and 1.0 .I want to do a control like -5.0 to 5.0 with the slider.How shall I change the limits of the slider?
                    Anton_S
                    There are two ways of doing it:
                    1. Change slider min/max parameters. Set slider controller to:
                      slider("range_control", 0, -5, 5)
                    2. Take the current slider ratio, subtract 0.5 from it, and multiply it by 10:
                      (slider("range_control") - 0.5) * 10
                    • Y
                      youthreewire
                      Earlier I wrote an API to control the servos from C code.That was working well with sketchup 7 with sketchyphysics 3.2. The example you gave uses the latest version of sketchup and runs in sketchup 8 for me but my C API does not work with sketchy physics 3.5.9. So can you give me the same example with google sketchup 7 running sketchyphysics 3.2 .Please.
                        Anton_S
                        Here is a SP3.2 compatible example:
                        motor-servo.skp
                        • Y
                          youthreewire
                          Thanks I will give it a try and let you know about my progress.
