    Custom tool creating instances of text labels
    5 Posts 2 Posters 605 Views 2 Watching
      sepultribe
      I'm in the process of making a Tool that will display some text labels on the Component entities that it gets clicked on. The text label contents will be drawn from a soap webservice but that is another subject. What I'm having trouble with is getting the tool to operate on each entity separately. Right now it will only work on 1 entity at a time.
      module SensorNodeInfoPlugin
      class SensorNodeInfoTool
        def initialize
          @selection = nil
          @info = nil
          @new_text = nil
          @label_exists = false
        def onLButtonDown(flags, x, y, view)
        if @label_exists==false
          pick_helper = view.pick_helper
          pick_helper.do_pick(x, y)
          @selection = pick_helper.best_picked
          @info = @selection.name
          arrow_x = @selection.bounds.corner(7)[0]
          arrow_y = @selection.bounds.corner(7)[1]
          arrow_z = @selection.bounds.corner(7)[2]
          text_x = 20
          text_y = 20
          text_z = 20
          @new_text = Sketchup.active_model.entities.add_text "", [arrow_x, arrow_y, arrow_z], [text_x, text_y, text_z]
          @new_text.text = "Loading #{@info}'s info..."
          @new_text.leader_type = 2
          @new_text.line_weight = 4
          @new_text.arrow_type = 4
          @label_exists=true
          else
          Sketchup.active_model.active_entities.erase_entities @new_text
          @label_exists=false
        def draw(view)
      end # module Sepultribe
      # Add the plugin to the menu, only once when the file is loaded.
      unless file_loaded?(__FILE__)
        command = UI;;Command.new("Display Sensor Node Info"){
          Sketchup.active_model.select_tool(SensorNodeInfoTool.new)
        UI.menu("Plugins").add_item(command)
      end # SensorNodeInfoPlugin
      If I understand correctly there is only one instance of the Tool at all times? I need multiple instances or is there some other way?
        Find an example Tool - like the Line-Tool script - there are dozens [e.g. My 2dTools scripts] - which take multiple point clicking - for a line instead of adding geometry from the clicked points you just add you label at its clicked point....
        You have a activate() method to set up the tool once, and that then runs a rest() method which starts the processing.
        You can have any Tool running until the user selects another tool etc...
        After the mouse-button-click code is done adding the label you then run the reset() method to set up for the next label...
          sepultribe
          Yes but I will need to be able to both create and delete text labels on each component that is clicked(show on 1st LClick, hide on 2nd LClick, and in between update the contents of the text label at specified second intervals). Will that work with the above philosophy or will it need that I create a class to hold references to which text label is attached to which component and detect which one is clicked and delete it? I'm really confused.
            Here's how I would do it...
            Let's first assume that a component-instance has no label.
            The user clicks on it.
            It is confirmed as a component-instance.
            It is also checked for a special attribute, tid=instance.get_attribute("SensorNodeInfo", "tid", nil), in this case it returns nil as it has no label.
            unless tid
              ### add_label_code
            else
              ### delete_label_code
            The 'add_label_code' will make the Text object, and give it a 'tid', a matching 'tid' will also be given to the picked instance...
            ` tid=Time.now.to_f+rand
            instance.set_attribute("SensorNodeInfo", "tid", tid)
            some code to add the Text object - referenced as 'label'
            label.set_attribute("SensorNodeInfo", "tid", tid)`
            Now the instance and its label are pair with a matching [unique] tid attribute.
            The 'delete_label_code' erases any related 'label', by matching its 'tid'.
            The 'label' Text object will have been previously given a unique 'tid' returned in the 'instance' match that was NOT nil, so you need to iterate the instances context to get possible candidates,
            labels_to_go=instance.parent.entities.grep(Sketcup::Text).select{|e| e.get_attribute("SensorNodeInfo", "tid", nil)==tid }
            then
            instance.parent.entities.erase_entities(labels_to_go) if labels_to_go[0]
              sepultribe
              unless tid
              >   ### add_label_code
              > else
              > end
              then
              Thanks that's very helpful.
