Graphic Performance
qany model can be used in those systems... why would you need a special one?
and can you try using a simple plain style and test?
Normally I just put together what is called the "tunnel equipment". That is the equipment you see if you drive through the car wash. I have been working on a sample model that includes the building, the room of support equipment, the office for the car wash, and the lobby. On the outside of the building I also include both the payment booth and the vacuum system. When I put all of this together I wind up with a SU file just under 30Mb.
That is where I suddenly see the lag in performance.
I will send you a PM with a link to 2 versions of the file (Lumion & LumenRT). The model has a bunch of edges and other little things I have been trying to clean up.
But do you get the lag in a small simple su file?
No.....and it only started on the larger files recently.
Register LoginAdvertisement
