    Mac OS -model info window instead of cursor
    3 Posts 2 Posters 634 Views 2 Watching
    • jojo9J Offline
      jojo9
      often i use the move tool (m), or i insert a component from the compo. browser and then, try to switch to the cursor.
      -the cursor is spacebar button on Mac-
      but instead to switch to the cursor, Su opens the model info window. I had that problem also with prior free/make- Su versions.
        driven
        hit F7 toggle your System preferences that are over-riding your SU shortcuts...
        it's a common issue, but i'm off to bed so will add more info in the morning...
        john
        • jojo9J Offline
          jojo9
          Driven, im surprised. I like very much how i set the button/focus accessibility on my system and havent suspected that feature to interfere with SU. Its like you said: turned off, Su behaves again like expected.
          Thanks for helping. πŸ‘
