    Trouble closing faces
    3 Posts 2 Posters 527 Views 2 Watching
    • A
      alas
      Hi all - I've used sketchup a while but I'm no expert. this is frustrating me. I have part of a model that refuses to let me close a face. I pasted the relevant bit into the attached. It seems to me that if all the edges of this cuboid are on axis - and if you colour them, they are - and there are no stray ends (I used Stray Lines - there are none, and besides, if there were, the side faces wouldn't close), then the top face must be coplanar and close. But it doesn't. And when I draw 2 diagonals, they don't seem to touch each other, as I can't select a one-quarter triangle, only two overlapping one-half triangles, and the fourth quarter won't even fill.
      If anyone can explain this before I throw either the computer or myself out of the window I would appreciate it hugely.
      Alastair
      cube.skp
      • cottyC
        cotty
        The 4 corners don't have the same z-coordinate (are not coplanar). You tried to check this with the "color by axis" option, but this has a little tolerance which was too big in your case! Move all vertices to the same height and it will work...
        my SketchUp gallery
        • A
          alas
          Thanks for your reply cotty - I am gobsmacked that I have to worry about thousandths of a millimetre! Got the test piece to work - now just have to apply it to the model…
          Thanks again
