    Shed Roof
    26 Posts 8 Posters 6.5k Views 8 Watching
      A quickie sketch to illustrate a method for constructing a roof for a small shed.
      I made one like this about 12 years ago and it is still going strong.
      • cottyC
        cotty
        Nice style combination!
        my SketchUp gallery
        • pbacotP
          πŸ‘
            Thankee gentlemen.
            FWIW, I used the same line style for the drawing and the frame. The two different line weights in the drawing were created using different export sizes.
            • JQLJ
              JQL
              It's looking good! Are those connectors wooden too?
              www.casca.pt
              Visit us on facebook!
              • KrisidiousK
                Krisidious
                That's not a Shed Roof... That's the roof of a shed. Trickster.
                By: Kristoff Rand
                  JQL, thank you. "Connectors?" I assume you mean the gusset plates joining the parts of the trusses together. Yes. Those are 1/4-in.-thick plywood from scraps I had on hand. They were glued and nailed in place. All but the end trusses have them on both sides. The sheathing on the outside of the walls does the job of the gussets on the outside ones.
                  Kris, it's my version of a shed roof. πŸ˜„
                  • JQLJ
                    JQL
                    Gusset plates... I don't even know their name in Portuguese...
                    www.casca.pt
                      Commercially made trusses in this country would typically be joined with nail plates like this:
                      http://www.hobbithouseinc.com/personal/woodpics/images/nailplate.jpg
                      Those are difficult to drive by hand with a hammer, though. I expect most framers would turn their noses up at my work but that roof and the whole shed is more than strong enough for what it is. It's certainly not built like the first or second little pig's house. πŸ˜„
                      • JQLJ
                        JQL
                        I like yours. Those metal ones are really bad looking...
                        Do they do that in order not to cut joints on the wood?
                        I don't believe that plate in the first image would even be needed in a typical truss if it's the middle joint...
                        www.casca.pt
                          Thanks. I like mine better, too.
                          There's no proper joinery done in truss building in the US. The ends are cut to fit together but it's no like a timber framed structure where they use mortise and tenon joinery. If it weren't for those nail plates a truss would just be a pile of sticks.
                          • KrisidiousK
                            Krisidious
                            Oh you think your Shed is Strong do ya Dave? Check out the Structural Integrity of the Shed in my backyard... The Big Bad Wolf can Huff and Puff all he wants... Not gonna blow this house down.
                            By: Kristoff Rand
                              Did you just build that? πŸ˜†
                              • JQLJ
                                JQL
                                Those are very "photoreal" Kris!
                                www.casca.pt
                                  Agreed! The extension ladder and lawn mower almost look real. And I like how you added that flare at the lower left corner of that first image. What render settings do you use for that? πŸ˜†
                                  • KrisidiousK
                                    Krisidious
                                    Can you believe this thing stands up? I think the paint on the siding boards is the only thing holding it up.
                                    By: Kristoff Rand
                                      Ladder keeps the house standing ? πŸ˜„
                                      • JQLJ
                                        JQL
                                        Stairways to heaven
                                        www.casca.pt
                                        • KrisidiousK
                                          Krisidious
                                          What's worse is that I store a Jaguar in it...
                                          By: Kristoff Rand
                                            I bet there aren't any rodents in it.
                                            • 1 / 2
