    Transformation.x/y/zaxis and transformation.axes
    4 Posts 3 Posters 590 Views 3 Watching
    • O Offline
      oajfh
      Silly question, but...
      Why do the transformation.xaxis,transformation.yaxis and transformation.zaxis methods return points, whereas the transformation.axes asks for vectors as input ?
      To be honest, I don't see any instance where I would use an axis as a point rather than a vector. That might just be me. But the fact that I have to convert points back into vectors afterwards does seem counter-intuitive to me.
      (it's not something that's bothering me, I'm just curious as to why things are so)
        slbaumgartner
        Error in the Ruby API documentation. They return Vector3d objects. If t is a Transformation, try t.xaxis.class
        • O Offline
          oajfh
          Is that so ?
          I'll have to check some of the code I wrote then, because I made the conversions and it worked as I expected to. Perhaps there's an implicit point to vector conversion or vice-versa, but in that case the API makes no mention of it.
          • Dan RathbunD Offline
            Dan Rathbun
            In mathematics, both are represented as arrays.
            ** class](http://www.sketchup.com/intl/en/developer/docs/ourdoc/array.php)":1hykbm7x]
            Introduction
            The SketchUp Array class adds additional methods to the standard Ruby Array class. Specifically, it contains methods allowing an array to behave just as a Vector3d or Point3d object (which can be thought of as arrays of 3 coordinate values.) Therefore, you can use the Array class in place of a Point3d or Vector3d as a way to pass coordinate values.
            The opposite is also often true, as well.
            The API docs need updating in regard to allowable parameter types.
            P.S. - The docs are misleading when it says "The SketchUp Array class ..."
            There is only one Array class. The SketchUp API just modifies the Ruby Array base class.
            πŸ’­
            I'm not here much anymore.
