    Transformation.x/y/zaxis and transformation.axes
    4 Posts 3 Posters 441 Views 3 Watching
    • O Offline
      oajfh
      Silly question, but...
      Why do the transformation.xaxis,transformation.yaxis and transformation.zaxis methods return points, whereas the transformation.axes asks for vectors as input ?
      To be honest, I don't see any instance where I would use an axis as a point rather than a vector. That might just be me. But the fact that I have to convert points back into vectors afterwards does seem counter-intuitive to me.
      (it's not something that's bothering me, I'm just curious as to why things are so)
        slbaumgartner
        Error in the Ruby API documentation. They return Vector3d objects. If t is a Transformation, try t.xaxis.class
        • O Offline
          oajfh
          Is that so ?
          I'll have to check some of the code I wrote then, because I made the conversions and it worked as I expected to. Perhaps there's an implicit point to vector conversion or vice-versa, but in that case the API makes no mention of it.
          • Dan RathbunD Offline
            Dan Rathbun
            In mathematics, both are represented as arrays.
            ** class](http://www.sketchup.com/intl/en/developer/docs/ourdoc/array.php)":1hykbm7x]
            Introduction
            The SketchUp Array class adds additional methods to the standard Ruby Array class. Specifically, it contains methods allowing an array to behave just as a Vector3d or Point3d object (which can be thought of as arrays of 3 coordinate values.) Therefore, you can use the Array class in place of a Point3d or Vector3d as a way to pass coordinate values.
            The opposite is also often true, as well.
            The API docs need updating in regard to allowable parameter types.
            P.S. - The docs are misleading when it says "The SketchUp Array class ..."
            There is only one Array class. The SketchUp API just modifies the Ruby Array base class.
            I'm not here much anymore.
