    Any suggestions to improve this render.
    6 Posts 6 Posters 967 Views 6 Watching
    • zimmerklZ Offline
      zimmerkl
      Created with V-ray and PS
      • omiKronO Offline
        omiKron
        First of all, desaturate the very green vegetation which catches too much the eye, much more than the building itself. Then add some street accessories, like light poles, grunge paving textures. You also can add some interior apparent lights to give a visual impact.
        • KrisidiousK Offline
          Krisidious
          It's a beautiful render... The focal point cannot be denied.
          I'm not much for the grunge and grime on new construction renders as omiKron suggested. I can see the point of doing it, but to me if you were going to do that, you should also age the building and no one wants to see that in new construction renders. It a great thing to be able to do, but I don't see the reason in putting so much effort into such things on new construction.
          1. I might agree the grass is too green, but I'm not landscape architect and I don't know the species or the natural color. I would check... It definitely pops, but I kinda like the modern feel of the grass.
          2. I do, because I'm looking for it, notice some identically placed plants, though they are spaced away from each other...
          3. The trees on either side look to be very similar in size and structure, while it's not obvious they are the same, it seems the might be. Rarely do trees stand the same height without human assistance.
          great job...
          By: Kristoff Rand
          • beginnerB Offline
            beginner
            I like the building, glass looks fine, first plan grass really good...
            I would tweak:
            1. Trees to the right - you can see the repetitiveness, I would add shadow from the trunk
            2. Tall grass - too strong for me, and you can see the repetitiveness
            3. Wooden Screen - variation of wood texture for each slat would be appreciated
            Regards, SU 'beginner'
            • DanielD Offline
              Daniel
              I think I would change the composition. The straight on center shot is kinda dull. Look at it slightly from the left, at an angle (not from the right, the wood fence would block too much). And if you could, add some life to it. And a smidgen more sky above.
              It's still a nice rendering, as it is.
              My avatar is an anachronism.
              • JonFarJ Offline
                JonFar
                i think the problem with the tall grass is that its too repetitive, like copied blocks of grass...
                just like the tiles on the sidewalk, they are all the same texture, and it shows
                also some sky and ground elements, like the guys said: light fixtures, urban elements, some birds in the sky, etc
                about the colors, i would tweak it to a little bit warmer colors
                it is actually pretty nice as is, but you asked for sugestions to improve, theres my 2 cents
