    Section Cut Face
    5 Posts 2 Posters 898 Views 2 Watching
      Lodewijk
      I downloaded Section Cut Face and put it in the plugin folder (yes, it is really there), but it does not show up in Skp Extensions. What can be the problem?
      Is there an other plugin for this? I will use it to make construction details withh Sketchup 15 Make.
      Thanks for help!
      Lodewijk
      • JQLJ Offline
        JQL
        Select a section;
        RIGHT CLICK on it;
        Search for SectionCutFace on the context menu that poped open.
        PS: You shouldn't drag plugins to the folder anymore. You should download Sketchucation Plugin Store and install through there. (You could also use Extension Warehouse from Window > Extension Warehouse, inside Sketchup)
        Plugin Store Download | SketchUcation
        Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
        (sketchucation.com)
        www.casca.pt
        Visit us on facebook!
          Lodewijk
          @jql said:
          Select a section;
          RIGHT CLICK on it;
          (sketchucation.com)
          Thats what I did, but when I try to download it from sketchucation plugin-store I get this message:
          "You can Write to the Main Plugins Folder, and...
          You have a Custom-Plugins Folder." When I open Sketchucations Plugin Manager its there, and it is activated too. But its still not in the tab Extensions, from where you always open an extension when needed.
          • JQLJ Offline
            JQL
            @jql said:
            Select a section;
            RIGHT CLICK on it;
            www.casca.pt
            • JQLJ Offline
              JQL
              @lodewijk said:
              But its still not in the tab Extensions, [highlight=#ffff80:adar9nmm]from where you always open an extension[/highlight:adar9nmm] when needed.
              This is the assumption that is making you stall.
              A lot of plugins are not accessed from the Extensions Menu.
              Some of them are contextual, like this one;
              Some of them are inside other menus, like Fredo's usually are inside tools;
              Some are accessed by Toolbars;
              Some are accessed when singing to the right rithm;
              Some of them are not accessed at all and only show up on an event, Like componente flag, wich only pops up when you edit a component;
              Etc...
              www.casca.pt
