    [Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
    25 Posts 8 Posters 19.3k Views 8 Watching
    • O
      oheimala
      Thanks for your excellent tool. I use it for calculating weights of the components. Would it be possible to add there an input field for the density and then show the weight? I have not found such tool made already
      Dave RD fredo6F 2 Replies Last reply
        Dave R @oheimala
        @oheimala that sounds like a nice option for this tool. FWIW, TIG's Center of Gravity extension will calculate the weight/nass of objects based on the density you enter into the UI. And you get the CoG located, too.
        • fredo6F
          fredo6 @oheimala
          @oheimala
          This sounds possible, but a little bit of work for the GUI (density field and choice of units for weight).
          I would do as suggested by Dave R. There are specialized plugins, who can handle much better the real caes where the density varies by object.
          • J
            jure
            Hi Fredo... I noticed that SolidVolume still displays volume sometimes differently than other tools:
            https://drive.google.com/file/d/16MUlyC0d4lm0HtqrOzJ6Hpf43_rMrboO/view?usp=sharing
            fredo6F 1 Reply Last reply
            • fredo6F
              fredo6 @jure
              @jure
              Thanks for signaling the problem. I actually forgot to update the plugin.
              It's now done with FredoTools v4.5c, just published.
              • 2 / 2
