    A way to save Toolbar info?
    4 Posts 2 Posters 286 Views 2 Watching
    • JClementsJ Offline
      JClements
      Is there someway ruby can store your Toolbar info (how they are docked and what is active) and then be used to restore that configuration or be used for other SU installations?
      I may be doing some training and this would be help setting up the PCs prior to instruction (some may be student's private laptops).
        JClements
        SU 2014.
        • CadFatherC Offline
          CadFather
          yes, there is. running 2015?
          i attached a small batch file. when you run it it will ask you to give a name to your back up file (which is a registry file). that way you can easily save more than one.
          the result will be a 'reg' file on your desktop. (public)
          if you open the script you can change directory etc..
          when you want to restore, just double click on the reg file, accept the warnings and all previous settings are restored.
          SAVE SETTINGS.zip
            CadFather
            ok, just change the number inside the file to 2014
